So i return after setting down my headphones and i see all these error messages for programs like Ventrilo, etc... The sound is gone, and No Audio Device is found
This is a pic from the Device Manager
http://img467.imageshack.us/my.php?image=helpzz3.png
I have an on board sound card i guess.
System Info: [code:1:afe903daa0]Windows XP Home Edition Service Pack 2 (build 2600)
Intel Corporation
2.40 gigahertz Intel Pentium 4
8 kilobyte primary memory cache
512 kilobyte secondary memory cache
Board: Intel Corporation D845PESV AAA97671-107
Serial Number: AZSV32013520
Bus Clock: 133 megahertz
BIOS: Intel Corp. SV84510A.86A.0017.P09.0304251748
04/25/2003
250.05 Gigabytes Usable Hard Drive Capacity
192.64 Gigabytes Hard Drive Free Space
BF3315A HLA591I SCSI CdRom Device [CD-ROM drive]
MITSUMI CD-ROM FX54++M
SONY DVD RW DRU-810A [CD-ROM drive]
WDC WD2500BB-00GUC0 [Hard drive] (250.06 GB) -- drive
0, s/n WD-WCAL79065146, rev 08.02D08, SMART Status:
Healthy
1024 Megabytes Installed Memory
Slot 'J6G1' has 512 MB
Slot 'J6G2' has 512 MB
c: (NTFS on drive 0) 250.05 GB 192.64 GB free
Intel(R) 82801DB Ultra ATA Storage Controller - 24CB
Primary IDE Channel [Controller]
Secondary IDE Channel [Controller]
NVIDIA GeForce 6800 GS [Display adapter]
Default Monitor
NERO IMAGEDRIVE SCSI Controller
SCSI/RAID Host Controller
Intel(R) 82801DB/DBM USB 2.0 Enhanced Host Controller -
24CD
Intel(R) 82801DB/DBM USB Universal Host Controller -
24C2
24C4
24C7
SoundMAX Integrated Digital Audio
USB Audio Device
802.11g Wireless PCI Card
HID-compliant device (2x)
USB Human Interface Device (2x)
PS/2 Keyboard
HID-compliant G5 Laser Mouse
USB Composite Device (2x)
USB Root Hub (4x)[/code:1:afe903daa0]
Sponsored Links
please unisntall and reinstall all your drivers for your sound card
Reply to edklite
Is there any audio device in start>>cmd>>dxdiag>>sound?
Reply to _path_finder
Quote :
Make sure you have the latest drivers as well as BIOS.
Reply to g-paw
Yes i have the latest drivers, and i have un/reinstalled
Under Sound in dxdiag it says:
No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Reply to eluden
In Safe Mode I'd run AdAware and Spybot Search and destroy and I would also clear the CMOS since you're using onboard sound.
Reply to g-paw
How do you clear the CMOS?
Any other tips?
Reply to eluden
Quote :
Any other tips?
The instructions to clear the CMOS will be either in your motherboard manual or in the manual you got with the computer if you didn't build it yourself. If you don't have the manual, should be on the mfg website. It just involves moving a little piece of plastic covering little pins on your mobo. The pins are usually near the battery.
Reply to g-paw
its not recognizing your drivers perhaps, are you sure the system knows where the new drivers you have installed are?
Reply to edklite
what do you mean ed?
Reply to eluden
I mean what folder in your PC did you install the drivers? after install did you go to device manager and point the sound device to that folder for drivers?
Reply to edklite
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > No Sound! Please Help
There are 1123 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
