Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Installed Media Center 2005 upgrade: Having some problems
First off, thanks for taking the time out to look at this. Here's my problem:
I installed the 2005 upgrade from my HP media center 2004. It was working fine for about 2 weeks. Now all of a sudden my system is very sluggish, often freezing for about 2 seconds at a time. Also, when I try to open programs now (firefox / AIM / etc..) it takes over a minute for them to open (rather than a few seconds like it normally does). I've tried the following to fix this.
cleaned registry (CCleaner)
ran virus protector (Norton) (No viruses)
ran spyware programs (No spyware detected)
Installed all the latest windows updates
None of this helped. If anyone can help me fix this problem I'll be in your debt forever!
(HP Media center 2005 XP/ 3.2 ghz pentium 4 / 1 gig of ram )
Thanks guys,
Joe
Sponsored Links
Hmmm... my MCE was slow at first but this program cleared up a few things. Try a full scan, correct all problems, and see if you notice a difference:
Advanced WindowsCare Personal
Hope this helps! :)
Reply to Wonderwill
- 0 +
running "spyware programs" does not mean you are clean, adaware and spybot are free but it does not mean they do the same job as spysweeper, so run spysweeper to be sure then post us your hijackthis log here ;)
Reply to edklite
There are 615 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
