Tom's Hardware > Forum > CPU & Components > CPUs > Cpu multiplier Problem
Forum CPU & Components : CPUs - Cpu multiplier Problem
Hello!
I bought a new motherboard (MSI 945P Neo3-F) for my system.
in bios the multiplier shows 8x(2.13 ghz) and in CPUZ 6x and changes randomly to 8x . Its the 'Intel speedstep technology' I know. But I cant disable it from BIOS(AMI), I could'nt find anything about C1E or EIST control so what should i do?
and does it have something to do with mobo or cpu because my old motherboar had a VIA chipset.
CPU: IntelĀ® Core 2 Duo E6400
Sponsored Links
Quote :
Hello!
Why do you want to disable? Do you idle your car at a red light at 6500RPM? :wink:
It's a worthwhile feature whose only side-effect is to have your computer run cooler, and to save you money on your energy bill. It will have no real effect on performance.
Reply to Phanboy
Correct. Unless the OP is going to overclock, it best to leave it on.
Reply to dasickninja
There are 1129 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
