Tom's Hardware > Forum > CPU & Components > CPUs > Cpu multiplier Problem
Forum CPU & Components : CPUs - Cpu multiplier Problem
Hello!
I bought a new motherboard (MSI 945P Neo3-F) for my system.
in bios the multiplier shows 8x(2.13 ghz) and in CPUZ 6x and changes randomly to 8x . Its the 'Intel speedstep technology' I know. But I cant disable it from BIOS(AMI), I could'nt find anything about C1E or EIST control so what should i do?
and does it have something to do with mobo or cpu because my old motherboar had a VIA chipset.
CPU: IntelĀ® Core 2 Duo E6400
Sponsored Links
Quote :
I've seen this question posted like 9088708263728906290437 billion times here. lol :)
Don't you mean like 09f911029d74e35bd84156c5635688c0 times?
It'll be in your bios somewhere, I am sure of it, if it's not there, then you're probably insane.
Reply to bigsby
have you found "Intel SpeedStep technology"? Just disable it.
Reply to 20070503
Quote :
Hello!
It is definitely in the BIOS, I have not seen a BIOS that does not have this as a configurable option... you may not be looking through to the correct menu/option screen.
JackMy 775Dual VSTA doesn't have it....and therefore...EIST doesn't work. Doesn't bother me though. :wink:
Reply to 1Tanker
on my DFI infinity 975x it appears as "frequency unlimit"
Reply to jumpman
Does anyone have this mobo....or any info about it ?
I will appreciate it. Thnx anyway .
Reply to duke4455
Try googling it for info on what to look for.Many times have I found my answer for some question with just such an aproach.You could also try going to the MB manufacturers web site and asking for assistance as they would be more able to answer your questions.Being that they work for the company and all.I'm not saying no one here knows what to do as I've personally gleaned quite a bit of useful info from here,and a lot of people really seem to know their stuff.I'm just saying that the MB comp.should be able to tell you exactly what to look for.Besides,it's called customer support.LOL.
Dahak
AMD X2-4400+@2.6 TOLEDO
EVGA NF4 SLI MB
2X EVGA 7950GT KO IN SLI
4X 512MB CRUCIAL BALLISTIX DDR500
WD300GIG HD/SAMSUNG 250GIG HD
ACER 22IN WIDESCREEN LCD 1600X1200
THERMALTAKE TOUGHPOWER 850WATT PSU
COOLERMASTER MINI R120
3DMARK05 13,471
Reply to Dahak
On my eVGA 680i board, the settings are in the ADVANCED CHIPSET FEATURES/CPU CONFIGURATION menu options. You should have something similar.
Reply to jsc
There are 1204 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
