I'm building my first computer, and ran into a fairly basic problem. I have a Antec Sonata II case, and bought an OEM Seagate 320 gig SATA HD.
However, I can't figure out a way to screw the HD into the case where the HD is supposed to go. Obviously, I'm missing some kind of bracket (or I really don't understand how to mount the HD).
What should I get to mount the HD, and where should I get it?
All you should need to mount an HDD in a new Antec case are four screws found in the box-of-bits found inside the case. These will fix the drive to one of the trays which run side to side of the case at the front bottom corner. The screws go in from the bottom of the tray into the bottom of the drive. Nice case btw.
