Need help designing Dual 8800gtx system
-edit: $1000 budget is gone. I need help with....
-Case, would like a window and major cooling power
-Power supply, 750watt?? I don't care about noise cause i never leave it on and game with headphones
-Mobo, i dont want to have to upgrade this within the next year.
-Ram, starting with 2 gigs but going to 4, i need slots
-CPU, don't want something ultra expensive, Id prefer around $300 if possible and id like the ability to add another eventually if possible
-HD, doesnt have to be big, just fast
-GPU, starting with 8800gtx but will be going to two
-Drives, Just 1 DVD-rw, and one DVD
Im gonna look through some previous builds but honestly im a nub when it comes to building comps. I just want a project for the summer. Anything im forgetting?
4 answers Last reply
More about need designing dual 8800gtx system
  1. Start with one of Sanji's $1000 builds. I like Core2Duo but for just gaming the AMD rig is awesome
    Sanji's Guide to Gaming PCs on a Budget
  2. The recent price drop of the E4300 makes it *even* more attractive as the basis for a budget PC.
  3. thinking about that intel ultimate $2000 build...
    but i decided im getting this case if everything will fit http://www.newegg.com/Product/Product.aspx?Item=N82E16811103008 anyone know?
  4. can't be sure but it looks like the bottom HD cage would be in the way of the GTX's
Homebuilt Systems Product
