Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Noise Dampeners - Do they really work?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Noise Dampeners - Do they really work?
So my computer is a little noisy (not that it bothers me a whole lot) but any little bit helps.
I was looking at a few products and I was wondering if they really work.
http://www.xoxide.com/thermaltake-sound-dampening.html
http://www.xoxide.com/sharkoon-pc- [...] g-kit.html
http://www.xoxide.com/nexus-disktw [...] black.html
Tell me what you think or if you have other suggestions. I'm also currently using 1 120mm fan and 3 80mm fan (part of the problem).
Edit:
Case: Praetorian - (PAC-T01-EK)
Case Fans: 3 Cooler Master 80mm - 2000rpm/24.4 dBA and in the rear I installed a 120mm -80mm case fan adapter so I'm running a 120mm in the rear.
PSU: Thermaltake 700W
CPU HSF: Zalman 9700 40c/60c
GPU HSF: Zalman (came with Gigabyte 7950GT) to lazy to check what model. Cant check temps (just reformated so not running Ntune)
I also having an Antec VGA blower, and I clean my computer pretty often. Its about 6 months old.
Sponsored Links
We need some details on your rig to give you good advice. Tell us your:
1. Case
2. Case fans
3. PSU
4. CPU HSF
5. GPU HSF
What are your system temps? When was the last time you cleaned the inside of your PC?
Sound dampening material does work, but there are a lot of things that you can do to remove noise before installing noise dampening material.
Reply to Rugger
Alright... I edited my first post.
Reply to pchoi04
Noise dampening material definitely helps. I use it in my case and I can notice a considerable difference with it than sans. Try www.frozencpu.com. They have some great noise dampening material.
Reply to korbin44
Quote :
What kind of stuff are you using on your computer?
I wonder how well Dynamat will work.
Reply to pchoi04
I tried the blue grommets in your second link. I couldn't make them work in my Silverstone or Thermaltake chassis. They're for HDD isolation, but ya need darn big screw holes. Someone elsewhere said they might work in an Antec chassis, but I'm not sure.
Reply to babaghan
Dynamat would probably work well. And for all you cheapos, carpet padding is also a good noise insulator, I used some when I installed some speakers in my car a while back and it worked like a charm, plus it was free.
Reply to Gary_Busey
Well... I just bought some Dynamat and I applied them to my 2 side panels and it seems to work pretty well.
Not a HUGE difference but pretty pleased with the results.
Reply to pchoi04
Quote :
Edit:
Here's an easy, cheap way to identify the noisy parts on your PC:
- Get an old cardboard tube - like at the end of a paper towel roll.
- Open the side of your case.
- Start the PC.
- Put the tube to your ear and point it at different fans or portions of the PC. This will help you isolate the noisy culprits in your system. If you want to upgrade to some of the quietest 80mm fans then take a look at this article. You can also take a look at the reference/recommended list on that site for quiet PC parts: PSU, Fans, efficient HSFs, etc.
Reply to Rugger
Quote :
When you add absorption, damping, etc., one rule of thumb is that the quietening achieved is a function of the mass of absorber. That works fairly well for sealed boxes. Computer cases have plenty of openings for noise to leak out, so it's a good plan to reduce noise at the source. I have some of the 11dB SilenX 8cm fans and they quieted down two of my PCs a bunch. If your mobo has a NB fan, consider a quieter fan or a good passive HS like the Thermalrights. You might also consider a good fan controller to slow them down.
Reply to clue69less
10 points.
*scurries off to try*
Reply to mugz
MP/Mugz: Glad you like the idea! It's helped me localize a few noisy fans - bearings starting to go on cheapo fans. Hope it works as well for you as it ahs for me in the past.
Clue: All good points. I haven't tried the SilenX series of fans. Lately I've been really pleased with good ole Yate Loon 120mm fans, D12SL-12. Low RPM, good airflow, quiet, and cheap. You can get them for $5-7 and they will perform as well as the $15-25 fans.
Reply to Rugger
Gullible is in the the dictionary. Whatya talking about?
http://dictionary.reference.com/browse/gullible
Reply to babaghan
*laughs to the gullible, questioning Babaghan*
Reply to mugz
Quote :
:lol: You have no idea how long I have waited for someone to post that :lol:
Reply to aoe
Quote :
Sorry, mate, you just dropped a few points on the IQ ladder... :lol:
Reply to SEALBoy
I agree with what Mpilch said. Use bigger fans, and pay extra to get quieter ones if need be. Just make sure they have a high enough CFM. As for HDD's, make sure you've got them screwed down, along with any cages that you can. The easy latches for cages and drives usually don't hold the drives securely and they can rattle a bit. Making sure everything is tight and the case has it's PCI slot covers on and secure can help muffle sound as well. I think a lot of dampening devices do nothing, they might make a noise a bit duller, but it's still present.
Reply to JonnyDough
Quote :
Someone had to take the bait. I've got no ego to bruise :D
Reply to babaghan
There are 1121 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
