Alright, last night I got my shipment from newegg:
GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX Intel
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
Intel Core2Duo E6600 Box Core2Duo 2.40GHz@1066FSB [From FRYS]
COOLMAX CUG-700B ATX 12V( V.2.2) 700W Power Supply - Retail
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB GDDR3 PCI Express x16
Seagate Barracuda 7200.10 ST3320620AS
Microsoft Windows Vista 64-Bit Ultimate for System Builders Single Pack
Okay, so I plugged everything together, and booted it up.It booted up perfectly. The IDE cable wasn't connected properly, so after I fixed that I booted the MS Vista DVD and installed Vista. It installed perfectly, no hitches at all. After I got in, I was doing some cleanup, and going onto the internet to grab a couple things, most notably current drivers for the 8800GTS.
After about 15 minutes of total time in Vista I got a BSOD, which of course doesn't stay up long enough for me to read anything, and a restart. The install disc was still in the DVD Drive, so it booted up from that again (oops). After the initial screen, it hung got hung up, so I turned it off.
When I turned it back on and I got nothing. I looked into the case and all the fans were running and everything seemed "normal." I cleared the CMOS through the jumper. Still nothing when I turned it on. I don't have a case speaker, but the front message LED was flashing slowly, and the manual says slow continuous beeping is a DRAM error. So I took out one of the RAM sticks. Rebooted and still nothing. I took out the second stick as well. Rebooted and still, nothing. I put second RAM stick in the first position. Rebooted and something popped up "BIOS Recovery...." or something similar. It restarted on its own and came to the logo screen. I entered the BIOS and turned it off. I tried putting the other stick in again (essentially, swapping the two sticks first configuration), and rebooted to nothing again.
Finally, I undid my last step and had only the one RAM stick that I successfully got the POST, and now I get nothing once again.
Please help, I don't know what else to do. Why would it work for 10 minutes and then crap out (bad memory from the start?). It was working for about 1.5 hours through install and use, etc. Furthermore, why would it work with the one stick, and then not work a minute later?
Thanks!
Rege
Thanks!
Rege
