Wireless Networking
Forum Wireless Networking : Wireless General Discussions - Wireless Networking
OK! so i just built my first computer and want to set i up for wireless internet but have never done it before.
I plan on buying these:
http://www.newegg.com/Product/Prod [...] 6833127158
http://www.newegg.com/Product/Prod [...] 6833127153
I am not sure if the rounter and adapter will work together, they use to have an adapter for the DGL-4300 but it is not on newegg or tigerdirect, right now.
Also imagining that those two worked together i get them home and connect my cable modem to the router and the adapter to the computer I want the wireless connection on and i can the just connect an ethernet cord from the back of the router to my other computer, right next to the modem and they will both have a connection right? after i install the software and such?
Any and all info will be apperciated very much.
Sponsored Links
Well I would suggest any atheros chipset that supports super g for that router. I have the DI-634M which has similar specs but better range and cheaper but doesn't have a gigibit switch. Check out cards like trendnet smc on the low end and dlink and netgear on the higher end. I use airnet cards although I think they went out of bussiness which is a shame cause they're dirt cheap and worked well. Just get it confirmed that its an atheros chipset although most things listing 108 mbps are.
Reply to brw02005
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Wireless Networking
There are 581 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
