Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > wierd internet problem (explorer?)...
Forum Windows XP : Windows XP General Discussion - wierd internet problem (explorer?)...
hi!
for the past two days ive been unable to login my yahoo mail (and the hotmail) acct (the mail site wont load for either sites - but www.yahoo.com and www.hotmail.com will...) and same goes for my bank acct. site...
can anyone guess what the problem is and how to solve it?
Sponsored Links
have you scanned your system for viruses and trojens?
Reply to edklite
theres nothing...
Reply to jorgito
what did you scan with?
have you checked your hosts file?
Reply to edklite
Not clear, are you using IE and is it the most recent version? If not, some back sites only work with IE. Have you cleared the cache, history, and cookies?
Reply to g-paw
its ie7 and ive never had a problem up till now... ive cleared all history and cookies and temp files... not working yet...
Reply to jorgito
Have tried to uninstall and reinstall IE 7? You could also try Firefox and see if you have the same problem. If you do, then the problem is something other than IE 7
Reply to g-paw
Quote :
http://img115.imageshack.us/img115/6421/whistling23gj.gif
Reply to edklite
There are 517 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
