I just built a new pc (see specs below) and fired it up and every thing worked... SWEET! I've built three other systems and never had everything working from the start. I booted it on and off a few times and everything was fine so I powered down it down and called it a day.
The next day I booted it up and had no video, %#@*%!, I heard the XP music come on but no video. I powered it down and check the all the connections and tried to re-boot and go into Bios. This time I still had no video and it didn't try to boot at all. All the fans came on, except the power supply fan, and the mobo led but it didn't boot. I then re-connected most devices and connections and tried to boot again, this time the power supply screamed like a small wounded animal and my mother board started to smell like it was about to burst into flames around the CPU! Ouch, my wallet was now starting to hurt.
I think power supply and mother board are toast, and maybe my CPU. Any ideas on what went wrong or how to test the parts to see which ones are damaged without starting a fire? Your esteemed help and advice would be greatly appreciated.
Intel E6600
ASUS P5N32-E 680i SLI
EVGA 320-P2-N811-AR GeForce 8800GTS 320M
Patriot eXtreme Performance 2GB DDR2 SDRAM
Thermaltake Purepower W0129RU ATX12V 600 W
ZALMAN CNPS9500 CPU Cooling Fan
Thanks, Zan
Intel E6600
Thanks, Zan
