Basically, I just got all the parts for my new system and put them all in the case and booted up for the first time. Everything was perfectly fine, BIOS booted, temperatures were great (CPU 29c, mobo 34c, etc) and everything looked fine.
The only thing I change were the RAM timings, BIOS was showing 5-5-5-18, but my RAM were rated 4-4-4-12 so I changed that and rebooted. BIOS came up fine and showed correct timings. Then, the computer just shut off. No warning or anything. So, I goto turn it back on and it does nothing. No fans turning or anything. So I try again and this is where things go bad. I see a bright flash at the top of the mobo (near the CPU) and smoke. I immediately turn off the power and assess the damage. There is a lot of smoke but no visible damage. So this is where I am, I didn't try turning it on again or anything like that.
So basically, what do you recommend I do? Have I fried everything and lost it all or is there something I can do? Thanks ....
