Sound Blaster Live! ct4830 or onboard sound?
xringx
Its an old card, 1998? Model is CT4830
Motherboard is Gigabyte ga-k8u-939 using Realtek ALC850 Audio AC'97 Codec
I use headphones for gaming (plantronics Gamecom pro 1 usb) and have a 2.1 desktop speakers.
When i play my game, i plug in the headphones. Otherwise its desktop speakers.
Questions.
1. Does the SB live! affect the usb headset sound? Or do they run independently?
2. which provide better sound?
3. I am mostly curious about the gaming sound, so if the answer to 1 is that sb live does affect the usb headset, is it better?
Thanks
Questions.
Thanks
answers
Last reply
More about sound blaster live ct4830 onboard sound
Questions.
Thanks
Buy a new card, that thing is way outdated and the onboard should easily outperform the SB.
I bought this for a friend about 6 months ago he loves it and has had no complaints.
If your looking to stick to a creative card though theirs always this. -
It doesn't really matter how old the card is - the only question is whether it can do what you want it to do or not.
If I am not mistaken, the USB headset is actually a sound device on its own - I don't own one and haven't messed with it. If it is a sound device, then when using it, you wouldn't be using the sound from either the onboard sound or the CT4830.
If you use the USB headset for gaming and your sound card for music then try the kX drivers for the CT4830.
kX - Getting Started Guide Guidehttp://kb.kxproject.lugosoft.com/guide/index.html
kX - latest drivers in this thread
http://www.driverheaven.net/general-discussion/128197-3538m-released.html
kX forum
http://www.driverheaven.net/kx-project-audio-driver-support-forum/
Sound Cards
Components
Product
Related Resources
- Sound blaster xfi black friday worth it?
- Looking for sound card suggestion
- Audigy 2 Platinum EX vs Sound Blaster X-Fi
- Sound Card help
- Is a old sound blaster live! pci...
- Sound Blaster X-Fi Titanium Headphone + Speakers???
- Need advice on new Headset
- Sound Blaster CT4830
- Creative Sound Blaster X-Fi Titanium no sound
- 'Crackling' sound in headphones
- Headphones
- Sound Blaster X-Fi Xtreme Audio delay between mic and headphones
- Sound Blaster X-Fi and the best headphones
- Can't find working driver for Creative Sound Blaster Live! (CT4830) (running windows 8)
- Creative Lab Sound Blaster X-Fi ExtremeGamer or Onboard Sound?
- What sound card when using headphones?
- Sound card advice ?
- Surround Sound Headphones
- Creative Sound Blaster X-Fi vs Auzentech X-Raider
- Headset Advice... Stuck between two.
