:hello: everyone.
I have put together a PC from bits, with Win98. It works OK.
I have installed an Ethernet PCI network adaptor so I can connect to the net but can't get it installed.
I notice the PCI card is 32bit and wonder if Win98 is 32 or 16bit?
The problem is getting the OS to install both the drivers for the router - both Ethernet and USB.
I know it's all a bit retro and it's only a hobby, but I learn as I go along with help from Forums like this :D
Thanks in advance.
Sponsored Links
:pt1cable: OK, it's 16bit and that's my problem. Sorted.
Reply to wotbus@
- 0 +
Every version of Windows from 95 on is 32-bit with 64-bit flavors of XP and Vista available. Even Windows 3.1 had 32-bit support, as 386+ processors were 32-bit. However, there was still a lot of 16-bit code in these OSes to make them more backwards compatible with older software.
Windows XP was MS's attempt to finally expunge 16-bit completely. However, there are still some out there using old 16-bit software... and some of it will suprisingly still run on XP. If I remember right though, they don't work at all under Vista.
------------------------------ Desktop: Windows 7 Professional 64-bit; Intel Q6600 CPU; E-VGA 780i SLI motherboard; E-VGA E-GeForce 8800GT; OCZ Vista 4GB dual-channel kit; Ultra X2 750W power supply; 2 x Seagate Barracuda 7200.11 500GB in RAID 0. Laptop: Acer Aspire 8730-6314;
Reply to Zoron
- 0 +
Thanks Zoron, that's cleared it up. I saw 32bit in bold type all over the software floppy for the PCI card and that caused the confusion.
I have that particular "DIY PC" on the back burner for the moment and will try again in the future. Thanks for taking the trouble to respond and clarify. :-)
Reply to wotbus@
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Connecting to router problem
There are 691 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
