Went to NEAR (Formerly Hosstraders) last weekend, and almost got out without buying anything. Feeling guilty, and found a motherboard for cheap, so got it.
Upon closer inspection, I can't find any identifying marks or insignia, though there are plenty of labels, and there is a serial number. I've searched on what mark-like text there is, to no avail. Nor have I seen a motherboard quite like it.
Distinguishing features:
Micro-ATX, Socket 370
i810 chipset - FW81810 and FW81801AB, no other Intel chips I can see.
2 DIMM sockets, 3 PCI slots, AMR on far side of PCI slots from CPU. (THIS is different from ANY Micro-ATX photo I've seen, so far. Usually the AMR is between PCI and CPU.)
Normal stuff, 2 IDE, floppy, normal back-panel
Extra headers for front USB, COM2
Despite being mostly jumperless, there are 3 2x3 pin headers with 2 jumpers on each, and one 2 pin header with a jumper.
Chip: 100+ pin TSOP
[code:1:a2ba16240e] VS930ADES
NSC 98 B2
AM95
MEGATRENDS
PC87366IBW/VLA[/code:1:a2ba16240e]
Chip: 32 pin in socket
[code:1:a2ba16240e] AWARD
1998
PCI/PNP 686
18087437
(Obviously BIOS, but what's the MEGATRENDS, then?)[/code:1:a2ba16240e]
Several lesser chips, but nothing major, obviously using i810 audio/video
Vacant chipsites:
[code:1:a2ba16240e]KM416S1020C (2 of them)
SOLOI
MILHOUS[/code:1:a2ba16240e]
Actually, I can probably figure most of the stuff out, none of it appears to be rocket science. But some of the headers aren't well labeled.
There is a "CHASSIS" 2-pin header - chassis interlock? short them?
HDDLED - 2 pins, obvious except no polarity markings
SPEAKER - 2 pins, 4 positions, obvious
RST_SW - 2 pins, obvious
SP_SW - 2 pins, "System Power SWitch?
MSG_LED - 2 pins, What Message?
RPW_SW - 2 pins, What?
PW_LED - 3 pins, What?
There are a few others, like WOL (Wake On Lan) 3-pin, WOR (Wake On Ring??) 2-pin, second CD-Audio connector marked "MONO", etc.
I'm about ready to just connect the minimal/obvious, plug in keyboard, display, some memory and a spare drive, and see what happens. Maybe leave "CHASSIS" open for the first try, short it if it doesn't power up.
Any suggestions, insights, warnings?
Chip: 100+ pin TSOP
NSC 98 B2
AM95
MEGATRENDS
1998
PCI/PNP 686
18087437
Vacant chipsites:
SOLOI
