I know how to adjust the line volume and mute, boost, disable enable. Everything is set in these properties. However as long as my mic is unmuted I can hear myself talking through the speakers. This occurs in any application(Word, IE, desktop) except the ones I want the mic to work in(Battlefield 2142, Sound Recorder, etc). In these instances the mic has no activity shown on the line indicator.
If the mic is muted or the sensitivity it is reflected in how well I hear myself in these applications. However again mic input is not recorded in the applications that is needed, ie to chat in game.
There is no muted options under recording, only under playback, and this does nothing to fix the real issue of no applications picking up the mic, and the mic does work cause I can hear myself.
If I mute the mic under levels, which is under playback>speakers>properties, I won't hear. But to have to leave it muted when not in use, and it not working in any mic apps when unmuted isn't right.
The reason it should be muted under playback (and for that matter, not even selected under playback) is feedback. Not so much an issue if you're using a headset... but still I find it extremely distracting hearing my voice echo back at me when I'm using voice. Double-check your sound settings in the control panel... remember that Vista has separate volume controls for different applications. (One for Windows and one for games, if I remember correctly). Ensure that the mic is enabled when you're playing games.
I don't care so much about the feedback, and at no time does the line indicator move while talking, and how does this get it to work in aps? Its a Creative X-fi.
It is enabled, and if i mute it under sound (can also just right click the speaker next the clock instead of control panel>sound) then great, I can't hear myself anymore, but no mic still either.
im kinda a mic noob but can someone tell me how to unmute your mic in vista home premium, cuz i think thats whats making my mic not work in bf 2142, please help.
Based upon what I've seen with my system, BF2142 has problems identifying the microphone under Vista. I can get the microphone working in other VoIP apps (Teamspeak or Ventrilo) but BF2142's VoIP setup app will not recognize microphone input. It's likely a problem that the devs will have to figure out, should they choose to address it at all.
this is my problem, i cannot get my mic to work on vista home premium for ventrilo. on one of my machines that has xp it works just fine but i cannot get a response of out if on vista premium
you guys might want to try updating your drivers too. i was having mic problems in tf2 and other steam games for awhile, mic would work but would come across really distorted to other players and occasionally not work at all. checked using sound recorder and mic worked as normal, so it was likely driver incompatibility. installed latest drivers and everything works as it should at default settings.
If you're using your built in drivers, most likely realtek HD drivers, definitely upgrade those. It'll take some of the load off of your processor, not much but some, and more than likely solve your problem. GL~!
Go into the Control Panel, click Sounds, and you should be on the Playback tab.
Dobbleclick on speakers, choose levels and notice there's a scrollbar! Scroll down to microphone and mute it.
Why Microsoft thought we should hear what we say in a microphone through the speakers is beyond my comprehension.
[1] --> Right Click the Volume Icon at the bottom right corner of your screen [The Task bar].
[2] --> Click [Playback Devices]
[3] --> Right Click the [Speakers] Icon and click Properties
[4] --> Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback (By clicking the unmute icon, than slide the volume up to where you prefer it... Simple I hope I was able to help someone with this...
If you do what you suggest, it will simply playback whatever you say into the mic through the speakers. The mic is not intended to be a playback device... it's a recording device... so those are the properties you have to adjust.
------------------------------Desktop: Windows 7 Professional 64-bit; Intel Q6600 CPU; E-VGA 780i SLI motherboard; E-VGA E-GeForce 8800GT; OCZ Vista 4GB dual-channel kit; Ultra X2 750W power supply; 2 x Seagate Barracuda 7200.11 500GB in RAID 0. Laptop: Acer Aspire 8730-6314;
Reply to Zoron
WOW, NONE OF YOU FAGGOTS CAME UP WITH ANY KIND OF HELPING ANSWER....**** ALL OF YOU. CAN SOMEONE FIGURE THIS **** OUT ASAP.......SERIOUSLY...**** ALL OF YOU LITTLE BITCH ASS PENIS LOVERS
how do you get microphone to even show on your tab, my friend has vista i sadly don't and am trying to help get the microphone to show on the volume tab but am unsuccessful thus far, any help would be greatly appreciated .
Hi, my problem is that in step 4 of your directions, there is no "Microphone Volume" slider, only HD Audio Output and PC Beep sliders. In other words there is no option to unmute there. There is a mic volume slider under recording devices>microphone>levels, but even when I adjust that it's still muted. I think I've looked through every "sound" related menu page, no luck. I'm using Vista Home Premium 64-bit.
However my laptop's built in mic does work when I play back a recording (as do other sound devices plugged into the external mic in jack, such as a keyboard or synth), but there is nothing coming from the speakers when using the mic in real time. This is really annoying because I used to use my old computer for recording and performing music, and in XP all I had to do was unclick "mute" in the sound properties menu. Now all my musical equipment/software is worthless if I can't hear anything while I'm recording it.
Does anyone else have this problem and know how to fix it?
It's not a problem... it's intentionally set up that way. I'm not sure how it works if you use an external mic, but I do know that you can't unmute the built-in mic... probably because of feedback issues. It's the same thing on my laptop... I'll have to check my desktop to see if it's the same with an external mic.
Reply to Zoron
Well after downloading the latest Realtek driver, I now have the Realtek HD Audio Manager in the Control Panel. It allows you to unmute the mic for playback... however when I did so, I immediately had to mute it again because of feedback.
So it's possible to do, but whether it's advisable or not is another matter.
Reply to Zoron
Do you have a built-in mic somewhere? Like in a webcam for instance? Windows might be defaulting to that instead of the external mic. Check your sound devices in the Control Panel and see if there are mulitple microphones. If there are, try selecting another mic.
Reply to Zoron
I know i've got the right device selected (the two are titled 'microphone' and 'line in' - I've selected microphone) because when I unplug my mic that is the one that changes status.
What I'd like to know is that if you're using the microphone to record... you should be able to hear what you're recording "real time" as you have to make noise in order for the microphone to pick it up. Same thing with the above poster... you're speaking into the mic, so therefore you shouldn't have to hear it through the speakers in order to hear yourself speaking. You can't edit in real time as you're recording anyway.
Reply to Zoron
im using it to record as well as change the pitch of my voice for stuff, but i need to be able to preview the audio through headphones for certain things like static and high volume level. in xp its easy to do because theres a checkbox to unmute the mic in volume control, but there is none in vista that i know of
Make sure you have the latest drivers available for you sound card. You may have to use your sound card's applet instead of the Windows mixer to get all the available options. For instance, in order to unmute the mic on my old laptop, I had to use the Realtek applet (Realtek HD audio) to unmute it... there was no option to do so under the Windows Volume Control.
Reply to Zoron
HELP!! MY PROBLEM IS DIFFERENT!! I CANT FIND AN ANSWER ANYWHERE!!
So my mic is internal and worked fine on msn and such but now i am in a different state with a different internet connection. The mic works fine and all tests can recognize sound coming through, however on msn when trying to do a live chat it does not work. The voice clip works, but not live. Also the call option on yahoo doesnt work, so its only live.
Hi,
I have the same exactly problem, as I have windows vista home premium 64 -bit. I am am using this discussion site for help.
Last night i went into bed 2:10 am trying to resolve this issue with no avail. As you rightly pionted out, it works in the recording mode. what I observed, in the recording mode, the sound come through the media player and I thinking if I can find some way to switch the sound from the media player to the speaker, it will work. If I get through, I will share. Wish me good luck,
