My apologies if this had been covered/posted somehwere before, it did not turn up in my searches.
I was looking if anybody had done any research into comparing the multitude of CPU and Generic (ie non-conforming GPU and Chipset Blocks) water blocks that are on the market?
I was thinking maybe comparing their BTU/hr, and then you can get their BTU/hr/$ for finding the best valued water block. Maybe using a controlled environment, seeing how many calories (or whatever, been a while since high school chem) a given water block can remove from a given substance (ice cube?). Or maybe placing it on a uniformly warm/hot surface and seeing how fast the coolant's temperature rises, therefore indicating thermally conductivity of the block.
Anyways, any body got a chart that shows the multitude of blocks out there? If not, it'd be a cool article for THW.
