Disk Defragmenter won't start in Vista, I click it and nothing happens. I've run chkdsk and googled but can't really find any answer.
There is also apparently no way for me to restart the 'task scheduler' service. I can set every other to restart at logon but there's nothing I can do with this one.
right click on stopped, and then restart it. You might beable to change the settings after that. If not it is because something else was turned off that it needs to run. I recommend turning everything that you disabled back on, and start over.
Task scheduler is system critical things like defrag wont work without it.
