News
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
90% of email estimated to be spam
Published on November 28, 2006
Despite rampant attempts to squash spammers, a new report from Internet messaging company Postini says that 9 out of every 10 e-mails is junk, an amount that is reportedly triple from what it was six months ago. Read more
Nvidia Contract Makers In Taiwan Low-key Over Defective Chip Reports
Published on July 07, 2008
Nvidia's Taiwan-based graphics chip contract makers are being low-key after the US chip designer informed investors on July 3 that will take a charge of US$150-$200 million related to expenses stemming from issues discovered with die/packaging materials used in previous generation notebook products. Read more
XP Service Pack 3 Kills AMD Machines
Published on May 09, 2008
Windows XP Service Pack 3 finally arrived to our computers this week… And is now killing AMD machines, according to Jesper Johansson, former program manager for security policy at Microsoft. Read more
Latest Reviews & Articles
Intel's Core i7: Blazing Fast, But Crippled O/C
Published on November 03, 2008
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
Possible PSU problem
Word :   Username :
Bottom
Author
 Thread : Possible PSU problem
Profile: stranger
More Information
Alright whenever I go to turn my computer on the fans start and the light turns on but nothing else turns on, not the optical drive, the monitor, the usb peripherals, or anything. Does anyone know if this is a PSU problem, or something else like a motherboard problem?
Specs:
PSU: COOLER MASTER eXtreme Power RS-430-PMSR 430watts
1 gb Corsair RAM
Intel 6300
Gigabyte ds3
Related Product
foz
Profile: member
More Information
Is the 4 pin cpu power connector plugged in? What kind of video card do you have? Your power supply might not be powerful enough with only 19amps on the 12volt rail.
Profile: stranger
More Information
The cpu 4pin connector is plugged in.
Video card: XFX 7600gs http://www.newegg.com/Product/Prod [...] 6814150166
THe PSU says it has 14A on the 12V rail so i have a different model 430W cooler master PSU.
foz
Profile: member
More Information
With only 14amps I dont think your power supply has close to enough power. Look at the PSU 101+102 stickey and get a power supply with at least 20-25 amps on the 12volt rail.
Profile: Forum Veteran
More Information
Did you change any parts? What happened right before you started to get the indications/failures to start? Do you have a PSU tester? These small/cheap tools are great for doing a quick PSU assesment.
There are two things that typically cause your symptoms: bad PSU or bad mobo. If the system has been running fine with all of the same components, then you have to try to eliminate either the PSU or mobo. The first thing that I would check is to make sure that the inside of the case is clean. If clean, then I would take a quick look at the capacitors on the mobo to make sure none of the capacitors are bulging/leaking. If the caps are good, then I would reseat all cards, RAM, and power connections to make sure they were properly inserted with good connections.
Try this stuff for a start and let us know what happens.
Google Ads
