Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > ATI X1650pro cd problem
Forum Graphic & Displays : Graphics Cards - ATI X1650pro cd problem
I just built a new PC and when I went to install the drivers for the x1650pro from the CD it says, "Setup was unable to complete the installation. Try to set up your display adapter with a standard VGA driver before running setup." .... so as you can see I am confused. If anyone can help I would really appreciate it.
Thanks
Sponsored Links
I suggest you download the drivers from the internet.
Drivers
I dont trust what they give you on CD's.
If that doesnt work call up Tech-support.
Reply to Xazax310
- 0 +
Thanks that worked! :D
Reply to Schnoz
There are 581 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
