News
XP Service Pack 3 Kills AMD Machines
Published on May 09, 2008
Windows XP Service Pack 3 finally arrived to our computers this week… And is now killing AMD machines, according to Jesper Johansson, former program manager for security policy at Microsoft. Read more
Studies show racing games promote risky driving
Published on March 15, 2007
Two separate studies, one in Germany and the other in the United Kingdom, have concluded that playing racing video games promotes risky driving behaviour, particularly among men Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Text Messaging Driver Charged In Hit And Run Death
Published on December 28, 2007
An allegedly text messaging driver has been charged in the hit and run death of a Taunton Massachusetts teenager. Read more
Latest Reviews & Articles
Power-Saving Motherboards: Fact Or Fiction?
Published on November 14, 2008
All motherboards support overclocking—now it’s time for power-saving. Here we evaluate products from ASRock, Asus, Foxconn, Gigabyte and MSI, weighing both performance and power consumption, to determine which P45 motherboard is most efficient. Read more
Overclocking Goes Int'l.: Overdrive In The USA
We're gearing up to start the international preliminaries of our Overdrive overclocking championship, which will determine who gets to graduate from Core 2 Duo to tweaking Core i7 965 Extreme. Read on for more about the vision behind this event. Read more
Does 790FX + SB750 = High-End Overclocking?
Published on November 13, 2008
AMD’s shift in focus to high-value multi-core processors has disappointed performance fanatics, but overclocking helps. We tested the company's latest enthusiast parts to find out if there are any real performance gains. Read more
Gaming Effects Versus Hollywood, Part II
Published on November 12, 2008
How far are PC graphics away from reality? Tom's Hardware takes a second look at the effects and tricks used currently by game developers to achieve more realism than ever before. Read more
  Tom's Hardware Forums » Motherboards & Memory » General Motherboard » Rebooting problem driving me nuts..
Word :   Username :
Bottom
Author
 Thread : Rebooting problem driving me nuts..
Profile: stranger
More Information
I work on computers for a living, but this has me stumped. Having a random restarting, apparently due to memory dumps in Windows (according to event logs and dmp files), and I am completely unable to isolate anything as the culprit.
Whenever I'm playing a game (ie: CS:S, LOTRO, etc) I get random mem dumps. The machine freezes for a second or two, clicks, then just blanks out and reboots. It may not do it for 2 or 3 hours, then all of the sudden hiccup. Usually after the first time, it does it again shortly after. This happens repeatedly.
I've run a crapload of hardware diagnostics multiple times and have had zero failures. Suspected RAM first, ran Memtest86 a few times, including about 10hrs straight yesterday (32 passes) and no problems. Even brought home a new pair of 512's to test and it still acted up. So that pretty much rules the RAM out.
I ran a couple video RAM tests that all passed, and 3DMark 05 -and- 06 both ran through the basic test fine. I had the issue with both my old PSU and my new 430W Thermaltake. HDD tests out fine for read/write/stress. CPU stress tests fine. It's definitely not a heat issue. I have no frickin clue whats left.
I'm beginning to suspect the motherboard. Does this seem like the only remaining possibility? If so, I'm about to just upgrade mobo/CPU/RAM anyway. Any suggestions or advice appreciated. TIA
Related Product
Profile: stranger
More Information
Anyone?? Below is the dumpcheck log file. Appears to be Southbridge? So should this tip me off that it's a bad motherboard?
http://i62.photobucket.com/albums/h81/grndnatnl/dump.jpg
Profile: member
More Information
Mmmmm... There are a lot of sound related files. I would suggest you that you disable automatic reboot of the system to see any blue screens that may appear.
Alternatively, you may try to disable the sound card in the BIOS and see what happens.
I'm pretty sure the issue is within the Mobo, but maybe is a driver problem.
Profile: stranger
More Information
Hmm. So possibly an issue with the onboard sound....
Disabled auto restart, but didnt think about it until later, so havent caught any BSOD's yet, but I'm waiting for one. I'll post up when I do.
I checked both MS Update and Epox for any hardware/chipset driver updates, and there are none. Everything is as recent as possible.
I'll keep posted.
Monkey wants to steal peaches
Profile: Faithful Poster
More Information
Any idea what's making the 'clicking' sound ?, does that PSU have thermal cut out ?.
Profile: stranger
More Information
I believe the clicking is actually the hard drive(s) parking the heads briefly before the system restarts.
Well, I disabled the onboard (AC'97) audio and installed an SB Audigy and so far so good. Havent spent a lot of time to be sure, but I'll be keeping an eye on it.
As far as the BSOD, it happens way to fast to read and restarts anyway, regardless of disabling restart on error.
Profile: stranger
More Information
Well it's apparently not the audio. The BSOD is too quick to read, and it still restarts. I'm pretty sure it's been narrowed down to CPU/mobo or running out of RAM. I could understand if LOTRO is hogging the RAM with only 1 GB, but certainly not CS:S.
Last night for example, it ran fine for about 3 hours before it finally froze and restarted. After the first time, it did it a couple more times closer together.
When not in 3D mode, or just idle, the machine will run all day long just fine. Will run diagnostics and memtest literally all day without a problem.
Profile: member
More Information
Did you check out the PSU? I had a bad one that caused random reboots.
Profile: enthusiast
More Information
So many things can cause bsod... since it passes all of the tests known to man and it is solid when not in 3d (and if you want to assume video is fine, which it probably is) then the only thing left is the mobo. I would have gone for heat first, then a PSU which it sounds like you have done (your new PSU is still kinda skinny for your setup).
You have my permission to drop a half-dime and get a new MoBo, cpu, and MORE memory. If you can wait a little - go for a quad-core @ $266(your cost will most likely be around $325). If nothing else, get 2x2G memory now, it's _really_ cheap...
Personally, I am waiting for bearlake, ddr3, and 45nm but if you gotta go - (like my ol momma used to say) life's a bitch (, you marry one,) and then you die...
good luck
Profile: member
More Information
I would check for a heat problem somewhere. 3 main areas are CPU, RAM and Video card. Especially the video card will give the random restarts, like when you're playing a game. I know with my card, the default fan speed was way too low so I had to manually set it and the restarts stopped.
Profile: stranger
More Information
Caught a BSOD:
MACHINE_CHECK_EXCEPTION
STOP: 0x0000009c (0x00000004, 0x805461f0, 0xb2000000, 0x00070f0f)
Profile: enthusiast
More Information
here ya go (but I think it's pretty much what you expected)...
and the follow-up
Understanding and troubleshotting MCE
Profile: stranger
More Information
Yeah..
Being that everything easily swappable has been swapped, that narrows it down to CPU/board. It's only a minor overclock, and all the voltages are stock except CPU which is at 1.55.
I now bumped the chipset up one notch from 1.2 to 1.3 and the RAM from 2.7 to 2.8 to see how it runs; maybe an undervoltage issue due to OC'ing the system. Just trying to make it efficient enough to last me a while 'til I can afford to upgrade.
Profile: stranger
More Information
Lemme know how it goes GrndNatnl. I have the exact same problem and error code. I've scoured the net but can't find any straight answers. Anyway, good luck!
Profile: stranger
More Information
I am finding this thread very intresting as I too am having the same shitty problem.
I have a Nvidia GeForce 7800 GS OC and I have just been told to install Ntune to detect the fan speed !
I have also disabled the auto-restart in set-up and I am thinking of going down the msconfing route and select the bare min. on start-up to try and see what the hell is causing it !
Keep it up guys !
Stalsy
