Hello every one !! it's great to be a member of this site .
i wanna build a new system and i chossed the parts , check it and give me ur advice .
1) Processor : AMD Athlon 64 X2 5600+ Windsor 2.8GHz Socket .
2) Motherboard : ASUS M2N-E Socket AM2 NVIDIA nForce 570 Ultra MCP ATX AMD Motherboard .
3) Ram : CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory .
4) PS : Thermaltake Purepower W0129RU ATX12V 600 W Power Supply 115/230 V .
other parts isn;t important now , i just wanna build a good system with good price .
thanx for replaying .
about overclocking , no iwont overclock any thing .
the usage for the PC is for gaming , i do some encoding but from time to time .
and about the power supply , do u have better company than TT ? i saw it's got a good power for the PC , with good price ..
Thanx heltoupee ..
i want some thing good for the graphic card , what do u think aout this power supply : Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V .
Check it here in New egg for Spec.
yeah, can't go wrong there. That power supply will do great.
From the motherboard that you've chosen, you will not be running SLI, so I'd think that you could drop any graphics card you want in there and have plenty of power to spare.
Judging from the caliber of parts you've chosen you're looking at an 8800GTS 320MB or possibly the low end 8800GTX, yes?
