Tom's Hardware > Forum > Linux/Free BSD > Linux/Free BSD General Discussion > Problem with Sata DVD drive installing Fedora 8
I just downloaded and burned a DVD of Fedora 8. When I try to install fedora it hangs for 10 minutes at loading "ata_piix driver" after the 10 minutes it continuse and asks where the install media is (CD, hard disk, NFS, HTTP, FTP) when I select CD it says that no device of selected type found. It then asks for either a driver disk or to select a driver from list. None of the drivers on that list seem to be the right one for me. I'm trying to install from an Asus Sata DVD drive to a 80GB WD IDE drive. Any help would be greatly appreciated.
System specs:
Intel Pentium Dual Core E2160
Abit IP35
2GB Adata DDR2-800
ATI Radeon X1950GT
500GB Samsung Sata
80GB WD IDE
ASUS 18X SATA DVD Burner with LightScribe
------------------------------ Deny Ignorance
Sponsored Links
Hi! Sounds like fedora automatically tried to install from the wrong device. (even though you could initially boot from it, i know, it's dumb.) You are ... (installing from a menu?) there should be something that says "source directory" and then somewhere down the line "install directory". Goto "select source directory" and it should either be in /media/dvd /media/dvd0 /media/dvd1 ...etc, OR in /dev/hda /dev/hdb /hdc... etc. It sometimes calls cdrom drives hard disks...
Does this help?
Reply to surrealdeal
There are 1170 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
