Help i cant get my formatting process to finish
  • Formatting
  • Hard Drives
  • Windows
Last response: in Windows 95/98/ME
May 8, 2011 12:34:59 AM
Hello,
I'm trying to format a new hard drive. It get's to 6% and sits there. I've tried it several times, I never get an error message it just doesn't move any farther. I'm a novice at this so wonder if I'm doing something wrong. I have to install windows 98 and then upgrade to xp pro. I thought it was a bad hard drive so bought a new one. It's the same with the new or old one.
More about : formatting process finish
Anonymous
May 8, 2011 11:47:06 AM
You can install XP from the upgrade CD without installing 98 first. You'll be asked to insert the 98 CD during the installation to prove ownership of a previous version of Windows.
m
l
