I dont know if I have a virus, adware, or spyware. This website keeps popping up about once every hour: http://www.aglocoo.c.la/ . I have tried everything to get rid of this pop up because it alt tabs me out of games and what not. I have tried norton anti virus 2008, no luck. I have tried all sorts of adware removing toosl and spyware removing tools that work on 64 bit systems. My operating system is Windows VIsta ultimate 64-bit. So I cant use ad-aware which is usually the best program imo. Any help on any recommendation for any program would be greatly appreciated.
did u try checking your registry or using hijackthis to see any entries that you dont know, sometimes pages like that install things in ur pc without you notice it, also reset your browser to eliminate any cookies or temp files. maybe this can help you.
i used hijackthis and to be honest the only programs I realized were legit were the games lol but I dont know enough about registry stuff to know what belongs there and what doesnt, maybe I could post what it gives me and you can tell me what belongs there and what doesnt?
Hey Dude , im facing the same problem too , did you find any solution for that ??
yes go to uniblue website and get spyeraser and registry booster I can say it has done a better job at fixing stuff than anything I've tried Microsoft certified
You will never turn back I promise
http://www.liutilities.com/ you can get rid of norton uniblue is got to be the best I have used lots in my time and this one really is good specially the registry booster
also go here to check out your Ip and see if its been blacklisted
http://www.robtex.com/
Message edited by gomerpile on 11-02-2007 at 11:42:02 AM
------------------------------WAITING FOR THE NEXT MOMENT TO STRIKE
Reply to gomerpile
