News
Graphics card makers expect Vista to improve profits
Published on September 23, 2005
Windows Vista, Microsoft's next generation OS, is expected to help graphics card makers see increased profits from rising high-end card demand, according to graphics card makers in Taiwan. Read more
Despite MMC Association and JEDEC collaboration, Samsung still dominates MMC platform
Published on March 22, 2006
With the MultiMediaCard Association (MMCA) and JEDEC recently announcing they will collaborate to develop a joint set of MMC memory card standards, Taiwan memory card makers expect the partnership to help counter the growing power of Samsung Electronics on the MMC platform, according to local memory card makers. Read more
Anti-spyware group publishes guidelines
Published on October 28, 2005
A coalition of anti-spyware vendors and consumer groups published guidelines Thursday to help consumers assess products designed to combat unwanted programs that sneak onto computers. Read more
Google Code Search peers into programs' flaws
Published on October 10, 2006
Security professionals warned developers on Thursday that they need to be aware that their open-source repositories can now be easily mined, allowing attackers to target programs that are likely to be flawed. Read more
Latest Reviews & Articles
Intel's Core i7: Blazing Fast, But Crippled O/C
Published on November 03, 2008
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
  Tom's Hardware Forums » PDA » PocketPC » help with reinstalling programs on new SD card
Word :   Username :
Bottom
Author
 Thread : help with reinstalling programs on new SD card
More Information
Archived from groups: microsoft.public.pocketpc (More info?)
HI,
I have an ipaq 1910 with a 256mb SD card. I have several
programs installed that I installed to the card.
I have a new 1 gig card I want to replace the 256 card with.
Can I just copy the contents of the 256 card to my computer,
then copy it to the new card and have all the programs still
work that I installed to the 256 card? It takes so long to
copy all those folders that I thought I would check first
for feasibility.
Thanks,
Mike
Related Product
More Information
"if6was9" <usenethotmail@hotmail.com> wrote in message
news:1123352519.159851.314520@g44g2000cwa.googlegroups.com...
> HI,
> for feasibility.
> Thanks,
> Mike
What is 'so long'?
It should work for most programs. Remember to look for any hidden files so
they get copied too. Some programs can use protection techniques (like a
hidden file in a particular unmovable memory location) that will mean
reinstalling, just see what doesn't work and reinstall them.
I'm a little surprised at the time factor though, it doesn't take too long
to copy my 512 Mb card using a card reader- it's around 20 mins using USB1.1
and all in one go for 500 Mb of programs and data. And how many times do you
need to do the transfer? Does it *really* matter even if it takes an hour
for a one time transfer- I bet it will take you an awful lot longer to
reinstall all of your programs.
You don't have to sit over the computer while it copies, or you can do other
things with the computer.
More Information
>> can i copy entire contents <<
short answer, yes...
you will only have to assure that the folder structure remains the same
after the process.
You may have to check your explorer settings to also assure that
hidden/readonly/etc files are copied as well.
Beverly Howard [MS MVP-Mobile Devices]
More Information
Do consider investing in a USB card reader. You will likely be able to go to
the store and buy one, and do the copying, faster than just doing the
copying via AS ;)
Sven
MVP - Mobile Devices
"Beverly Howard [Ms-MVP/MobileDev]" <BevNoSpamBevHoward.com> wrote in
message news:u43rUzrmFHA.2580@TK2MSFTNGP09.phx.gbl...
> after the process.
More Information
> > HI,
> > for feasibility.
> > Thanks,
> > Mike
> What is 'so long'?
Well I've got a lot of directories and files plus the program
folders, and when I just tried to copy a whole directory,
it would copy for say, 20 min, and then crash. Then I would
have to look for which files it *didnt copy, and go from there
and sometimes start over. So I will have to do this piece by piece.
However, if this is feasible, then it is definitely better
than reinstalling all the programs, so thx for your clarification.
It would be nice if I could just start activesync, right click on
the 'storage card' and then just copy *that, then paste the whole
thing into the new card. I think that might create a staggered
directory though called 'storage card', and would likely crash
on me as well during the copy process.
Mike
More Information
news:1123375800.354624.148890@g14g2000cwa.googlegroups.com...
>> > HI,
>> > for feasibility.
>> > Thanks,
>> > Mike
>> What is 'so long'?
> Mike
Activesync struggles with large sized files. Use a card reader, borrow from
a friend, but they are inexpensive and a lot faster for file transfers.
Don't forget to copy any hidden files.
More Information
I got the files transferred, and the new card, when inserted,
was automatically named 'Storage Card 2'. This '2' caused
the path of the start.exe's of the programs to not work.
When I tried to rename the first Storage Card folder, which was still
present in File Explorer, even though the card was not inserted, to
something
else, I got an error message that said I couldn't rename it.
I was then going to rename Storage Card 2 to Storage Card,
and see if the paths to the programs would work.
How do I get the new card installed and have it called
Storage Card instead of Storage Card 2?
Thanks,
MIke
More Information
We assume you transferred the SD card contents to another SD card correct?
>> 'Storage Card 2' <<
This is the behaviour experienced when the ppc shows that the original
card is still inserted.
Remove both cards and execute a "soft reset"
After the ppc reboots, insert the new card and run pocket file explorer
to confirm that the card is now recognized as "storage card"
More Information
> >> 'Storage Card 2' <<
Ok, this worked and about half of the programs now work. Thanks!
Will reinstall the others.
Mike
Google Ads
