Tom's Hardware > Forum > Applications > Other Software > Help with new system and database location
Forum Applications : Other Software - Help with new system and database location
I am in the process of building a new system and setting up hard drives. I could really use some suggestions on how to setup my drives for a relatively simple database program that will continue to grow. It was suggested to me http://www.tomshardware.com/forum/ [...] lution#bas to setup a Raptor X 150 gig HDD for my primary drive and a Barracuda 7200.10 for secondary drive. The database program is a third party app called Poker Tracker that runs of a MS Access DB. Eventually as the DB becomes much bigger, I will probably move it over to SQL. The primary function of this PC isn't going to be a DB Server and outside of this program, no other databases will be running or created. I am looking to build a system that I can multitask on while the DB is running. So I guess the application will be on the C drive while the DB is placed on the secondary storage drive. Is this the best route to take?
Thanks
Sponsored Links
There are 1317 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
