So I'm putting my new pc together as we speak. And I'm concerned with my power supply's headroom for future improvements. Currently I'm running an Antec NeoHe 500watt power supply. Now seeing as how I'm currently running an e6600, 3 hd's (raptor and 2 barracudas in raid 0), and an 8600gt it runs just fine. But I plan on using the step up program in two months to go to a 8800 GTX. If I keep the same power supply will my comp take a nosedive? I'm not willing to fry 1k+ in computer parts because of the supply. The recommendation for the GTX is 470, but does that mean it's max use on it's own is 470? 30 watts to run the rest of my s ystem seems less than promising.
look at the power use. That's with a quad core, Raptor, 2GB RAM and an 8800GTX. I'm sure you'll be fine. The amps on the 12 rail are the only big concern, and you have enough there too.
