Tom's Hardware > Forum > Windows Vista > Vista General Discussion > External Enclosure with SATA drive - problems!
Forum Windows Vista : Vista General Discussion - External Enclosure with SATA drive - problems!
I use Vista, but I'm not positive this is a Vista problem...
External Enclosure (SATA) in Vista - when I try to copy files to/from the drive, it says: "Could not find this item"
I recently put a 400 GB Samsung Spinpoint SATA drive into an External Enclosure. The drive worked fine when it was in my desktop (and still does when I transfer it back), but when I put it into the enclosure, strange things happen.
When I try to copy to or from the external (in Vista), it says "You must provide administrator permission to copy this folder."
You think "That's what Vista always does - make you click as many buttons as possible at all times." but on my roommate's external HD (an Element, not an ext. enclosure), Vista doesn't say I require permission to read/write.
Anyway, on my enclosure, it asks for permission, so I click "Continue" and then the screen comes up where it says "Windows needs your permission to continue" (more permission) - and THEN, it says "Could not find this item. This is no longer located in G:\Pictures\School. Verify the item's location and try again."
But nothing moved, nothing was unplugged, it just suddenly forgets where the item is.
If I put the same HD back into my PC (internally) right afterwards, it shows up and everything is accessible.
Any ideas?
Sponsored Links
There are 660 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
