I just recently purchased a DEll Vostro 1500 and here are its specks
Windows Vista Ultimate
160GB 54,000RPM SATA HDD
2GB DDR2 RAM 667
Intel C2D T7500 2.2GHz
NVIDIA 8600GT
The notebook has a SD card slot on the right side and I was wondering it it is possible to use Vistas Ready Boost feature with the SD card instead of a normal Jump Drive. What I would like to do if it is possible is purchase a 2 GB SD card (hopefully with fast transfer speeds) and configure it as a ready boost feature. Please let me know if it is possible or if there is a better way with hardware to boost up vistas loading time. Thanks for the help.
Message edited by tvh on 10-06-2007 at 04:46:38 PM
Ok, I've read that it is possible, but now I am wondering what would be good to use for the SD slot. I would like to have atleast 2GB but I would like to have 4GB (Might be overkill, but I chose 4 because that is the maximum amount of Virtual memory that a computer can use if I am not mistaken). Let me know your thoughts. Thank you
It's easy to use Windows ReadyBoost. When a removable memory device such as a USB flash drive or a secure digital (SD) memory card is first inserted into a port, Windows Vista checks to see if its performance is fast enough to work with Windows ReadyBoost. If so, you are asked if you want to use this device to speed up system performance. You can choose to allocate part of a USB drive's memory to speed up performance and use the remainder to store files.
Note: At least 1Mb of flash memory for every GB of ram. This is the ratio that I have ran across.
The only thing with windows ready boost is you will not notice that much of a difference with the amount of RAM you have, 2 gig is more then plently for the moment and the main function ready boost flash drives do is increase the speed of which paging and indexing files are found it may not neccesarily give you that boost in applications.
Where as if you say had 512mb RAM running home basic and then accuired a 1gig ready boost drive you would notice the difference
Overall you can get them for like under £10 by all means get one and have a go, i mean at the end of the day anything that takes the strain off any component is a bonus
------------------------------bill can suck my vista sack
Reply to mazuk
