I recently put together a system for the first time and everything seemed to be running fine. The other day when i had two games running (WoW and CS:Source) the comp restarted with no warning.
I had a friend tell me it could be overheating. I downloaded intel's temperature monitor and it after running the 100% load test the both cores kept rising to close to 90 degrees C.
I've checked to make sure that I seated the heatsink properly and I belive that I have done so. I don't have any extra thermal past applied as I'd seen several places that its not necessary on the newer processors as they have it pre applied.
Listed below is the hardware I'm using. If anyone has any suggestions about what could be causing this(or how to fix it) I'd appreciate it a lot.
Thanks,
Kaeta
Intel Core 2 4300
GIGABYTE GA-965G-DS3 LGA 775 Intel P965
NZXT Apollo
VGA 256-P2-N615-TX GeForce 7600GT 256MB
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
THERMALTAKE TR2 500W Power Supply ATX12V V2.0 - Retail
Thanks,
Kaeta
Intel Core 2 4300
NZXT Apollo
