Im wondering if I can use the stock Intel E6600 heatsink 80mm fan as a case fan for my side panel. Can I plug it into the another motherboard 3pin fan header instead of its usual 4pin cpu header?
my motherboard is the eVGA 680i and its got...
-CPU Header 4pin (taken)
-nFORCE Fan 3pin (taken)
-AUX Fan 3pin
-Chasis Fan 3pin
-Chassis Fan2 3pin
-Power 3pin
-Unlabeled 3pin
Thinking of trying the "Chassis Fan" first, I should expect this one to work best right?
Now the next thing, is how does such a fan work? I need to enter the BIOS, then System Monitoring? Then from here I can chose whether I want the rpm to stay a constant speed of my choice or auto, or this is done elsewhere, or its stuck on auto and cant be changed?
