I am currently running a dual boot, with Vista Home Prem x64 and XP MCE. I have not used vista an about a week but today logged in to check out Crysis in Dx10. I went to check my email and noted that Firefox and IE7 were not working. IE7 64 bit does work. I did a Google and found that this is a somewhat common problem, that for some reason the x32 portion of Vista x64 gets hosed. The only solution seems to be a)System restore or, b) reinstall Vista. This info is from Feb-April of this year. I am wondering if, before I go at a reinstall, has anyone discoverd any other solution? I do not have any system restore points so a reinstall may be my only option.
That's the first I've heard of a VERY odd problem... Took time time to poke around the web, and wasn't able to find any posts about "32 bit not working in Vista 64".
This looks like it's going to be beyond my very limited Vista knowledge, nor is there anything like this problem in the Vista books I have here. So what you might want to do is head over to http://www.msfn.org Some of the guys there are pretty serious code heads who would probably love to figure this one out.
Message edited by Scotteq on 10-30-2007 at 01:21:29 AM
------------------------------Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground? Or the ones who illegally pay vendors to not support the first group?
Reply to Scotteq
And this guy seems to know what's up with it but his "Fix" sucks for me.
" Here is what has happened.
You have blown out you 32 bit layer interface in Vista.
Any program that runs at 32 bit will not work properly.
Hence IE 7 standard will not work;but the 64 bit version will.
You can verify this by finding and downloading the 64 bit version of firefox. Its in beta but is available. you need to do a google search. All this will do is confirm whats going on. Anything that runs at 32 bit will not be able to access the network. Virus definitons cannot update, Any program that checks the internet for updates will not work.
Now the serious part. The only way I know of fixing this short of reinstalling Vista is go back to a restore point that was created and is available still. This restore point has to be prior to the problem occuring. If it is; run a system restore. My problem was I; went 1 week before trying a system restore ;so it would not work. Short of that a complete reinstall is required which is what I had to do."
I just got it the way I wanted it and a reformat would take 4 ever not to mention the risk of messing up my bootini leaving my XP install unuseable.
Ok took a LONG time searching Microsoft's forums but I found it. The Winsock got screwed up. The fix is as follows incse anyone else has this issue.
1. Click Start , type cmd in the Start Search text box, and then
press ENTER.
2. Type the following command, and then press ENTER:
netsh winsock reset
3. Restart the computer.""
NOTE: Must use cmd as admin
Hope this can help someone. After a bit of searching I found the problem many times but only one post with a solution that does not involve a clean install of Vista.
Message edited by bxmedic on 10-31-2007 at 05:04:50 AM
Reply to Scotteq
