News
Plastic Logic says it has developed largest plastic active matrix display
Published on December 05, 2005
Plastic Logic, a British developer of plastic electronics, announced that it has built a 10" flexible organic active matrix display - which the firm claims is the largest display of its kind to date. Read more
Samsung moves ahead with transmissive plastic TFT-LCD display
Published on March 16, 2005
From 82"es all the way down to five, we can clearly see the current gap between the leading edges of traditional TFT-LCD displays and plastic models. Read more
3D Systems drops price of 3D printer below $15,000
Published on March 01, 2006
3D printing is not quite what we would call a mainstream application, but the creation of realistic plastic models of products using a "printer" is becoming more popular with more businesses, product and marketing managers, designers and engineers as well as universities. Read more
RocketGuard 100 monitors temperature, alerts about failing PSUs
Published on February 07, 2006
HighPoint Technologies, makers of RocketRAID line of RAID controllers, has released the RocketGuard 100 monitoring card which keeps track of chassis temperature, fan and power supply health. The little card can be mounted anywhere within the computer case and has connectors to HighPoint's RocketRAID cards and chassis alert LEDs. Using the included software, users can set alert limits and be emailed when a fan fails or when the case reached a certain temperature. Read more
Latest Reviews & Articles
Roundup: The Best Overclocking Software
Published on November 06, 2008
Interested in overclocking but not quite sure where to start? We round up some of our favorite software utilities for tweaking processors, memory, graphics, and chipsets. Read more
Tom's Holiday Buyer's Guide 2008, Part 1
Published on November 05, 2008
Welcome to the first installment in our six-part Tom's Holiday Buyer's Guide. In Part 1, two beautiful models help showcase some of our favorite no-hassle hardware gifts for 2008. Read more
Round Up: Five Powerful, Light Ultraportables
Executives, road warriors, and gadget geeks all lust after ultraportable notebooks. Five of these amazing machines battle it out in this roundup. Read more
Core i7: 4-Way CrossFire, 3-way SLI, Paradise?
Published on November 04, 2008
For the first time ever, gamers are being treated to a reasonably priced platform enabling the best that AMD and Nvidia have to offer. Is Core i7 a gamer’s nirvana or does the processor serve up more of the same? Read more
  Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » advice on painting/dying plastic case parts
Word :   Username :
Bottom
Author
 Thread : advice on painting/dying plastic case parts
Profile: journeyman
More Information
Hi all,
I'm back asking more about my Antec Solo drive bay issue. I hope I'm not boring everyone, but I really want to keep the clean look of this case.
I want to turn these:
http://www.antec.com/Detail.bok?no=516
into a nice Piano Black to match the sides of the Solo.
First, should I start with a base coat of vynal dye or should I use gloss paint? The final coat will definately be a clear gloss.
Do I need to give it a primer?
Should I use a silver primer? I've heard it gives the colour more "depth."
Thankfully I've ordered a few of these, so I can probably get more than one crack at it.
Related Product
Sailing in my Dreams
Profile: Forum Veteran
More Information
I've done some painting in the past, but would not claim to be an expert. So take my advice for what its worth and if someone has better, than follow their's.
Yes, use a primer. A good primer will slightly etch the material and provide a better surface for the paint to adhere. I generally base the primer color according to the future color, in other words, a dark primer with a dark color and a light primer with a light color. This varies with the effect I'm trying to produce. Sometimes, when using clearcoats or "candy" types colors, I use a silver or gold primer to accent the final color, giving it some depth and highlights.
I've haven't used vinyl dyes, so I don't know how they would affect things. The only hang up I see with them is that they might permanently change the surface and make painting a different color in the future difficult.
If you are using a clear gloss as a final coat, it won't matter as much whether the base coat is gloss or not. That said, probably using a gloss base coat will give more of the depth that you want. Since you ordered a few of these, experiment a bit to see what gives you the desired result. I'd also try an experiment on a back side of a part so that it won't matter if it turns out bad.
My best experince in painting, and I admit this is personal taste as much as anything else, is to primer, sand, primer, and resand. Then I put on a few coats of paint, resanding every coat, and finish with a clear coat. This gives me a finish that has good depth, like you're looking through some water at the color underneath.
Again note, someone else may have a different or better way of painting than I do. I'm just writing based on the experience that I've had.
Google Ads
