G Guest Guest Oct 5, 2009 #1 using ubuntu O.S, while the gateway is not taking while setting IP address. Why?
G Guest Guest Oct 5, 2009 #2 This topic has been moved from the section General Networking to section Linux/Free BSD by Grumpy9117 Upvote 0 Downvote
sub mesa Distinguished Apr 17, 2009 2,914 0 21,160 Oct 5, 2009 #3 Please describe your question better. It sounds to me like you're not getting an IP address assigned by the DHCP server on the local network, is that correct? Could you give us the output of "ifconfig -a" in full? Upvote 0 Downvote
linux_0 Splendid Dec 18, 2005 5,314 0 25,860 Oct 6, 2009 #4 ifconfig eth0 192.168.1.2 up route add default gw 192.168.1.1 Good luck Upvote 0 Downvote
linux_0 Splendid Dec 18, 2005 5,314 0 25,860 Oct 6, 2009 #5 Replace 192.168.1. with your actual LAN IP range. If you're not sure what it is you can find it in your router if you have one. Good luck Upvote 0 Downvote
