Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
In the weird world of quantum computing, the state of computer systems networked together is so fragile that a read access to a single quantum bit, or qubit, on one machine would require a network-wide reset. Read more
Most booths at the Consumer Electronics Show are pretty bland, but Spectra International's booth stood out with several walls of eye-searing pink Hello Kitty electronics. The cat face with its trademark missing mouth, a symbol of international cuteness, was plastered on everything from phones to USB sticks. There were even Hello Kitty toasters and hair dryers on display. Read more
Taiwan-based AU Optronics (AUO), Chi Mei Optoelectronics (CMO) and Quanta Display have reportedly participated in LED chipmaker Formosa Epitaxy's recently applied capital increase and ECB (euro convertible bond) issue, according to the Chinese-language Commercial Times and Apple Daily . Read more
Recent price drops have made 4 GB DDR2 dual-channel kits affordable for even the most cost-conscious buyers. We pushed nine models to their limits to determine best value for a broad range of users. Read more
We tightened the budget on this month’s enthusiast-level system while loosening our belt for the low-cost gamer box by a similar percentage. Today we gauge the effect of these changes on performance and value and compare to last month's machines. Read more
On this, the second day of our System Builder Marathon, Don turns down the price tag of his mid-range build looking for a sweet spot just above the $1,000 marker. Let's see what sort of hardware he found for it! Read more
This month's System Builder Marathon is all about your feedback to us. We've revamped our entry-level and mid-range PCs with new price points. Let's kick things off with what we think is the best value at a $625 price point! Read more
| Bottom | |
| Author |
Thread : Weird Temp Issue, please help.
Profile: journeyman
More Information
Problem explained below. Please let me know what you think. First I will give you my temps and other stats of all my OC attempts.
Related Product
Profile: old hand
More Information
DOOHH!!, you broke it!!
Profile: journeyman
More Information
running Orthos on it now and it's stable (cross fingers) and at 51 degrees C. at full load. Who knows. I just don't see how the 102 degrees could have been right, maybe I was seeing things or it was a bogus temp reading even though ever monitoring program I had open was showing the same temp.
Never stop and reload... EVER!
Profile: addict
More Information
Turn on throttling. See what happens when temps get to 102.
Profile: journeyman
More Information
Profile: journeyman
More Information
I dropped everything back down to stock until I can figure this out.
Profile: stranger
More Information
I have this same problem on a p5b deluxe and e6600 but I would think its some kind of software error/bug because if you look at core temps, they don't have a large spike like the cpu temp. (cpu temp should be roughly 5 degrees below core temp so it makes no sense for cpu temp to jump like 60 degress higher than core temp)
Profile: journeyman
More Information
Profile: addict
More Information
Keep in mind that there is NO WAY to read the "actual" C2D temp via software. It doesnt have the capability. ALL programs are basically starting with a basline temp and using some assumed values, like Tj Max of 85C, and figuring the temp from there. Guessing, if you will, by making calculations using assumed numbers.
*Smacks turpit with a +15 ban stick*
Profile: Forum Veteran
More Information
To have a 60C jump in temp in 2 seconds, you would need to pull of your HS. That temp issue is nothing. |
Profile: journeyman
More Information
Profile: journeyman
More Information
Anybody have a suggestion on why it would do this? Is it just misreading my temp all of a sudden for some reason and I don't have anything to worry about? |
More Information
The spike is wrong, but I dunno about the general temp readings. |
Profile: addict
More Information
Sounds like a hardware monitoring error since multi programs that access the same "probe" gave those numbers. What to do about it? RMA the MB or at least call the manufacture and tell them what's going on with it. |
Profile: journeyman
More Information
Thanks, I guess I will email evga and see what they say. |
More Information
