Win98 FAT32 compression problem?
Last response: in Windows 95/98/ME
- Read damaged win98 Fat32 files and transfer them to Win2k Forum
- SolvedKingston Pendrive FAT32 problem Forum
- Solved80GB HDD, FAT32 formatted w/ USB case used as MP3 device in car problem Forum
- FAT32 has been change to RAW problem! Forum
- Hi. I had problem(((((((( when i connected usb that said only format. I formatted and choose file system fat32. Now cannot rec Forum
- Problem during upgrade win98 to winxp Forum
- Problem updating bios with Fat32 partition Forum
- W2000 with fat32 file system, modem recognition problem Forum
- Solvedwhen I open my computer screen show bootmgr is compressed,press ctrl+alt+del.how to fix this problem without cd Forum
- Audio Compression Problem Forum
- Problem while running XP's disk compression utility Forum
- Trying to install Win98 on new build to get to XP (problem) Forum
- Problems with FAT32 and Large Drives? Forum
- Win98 and WinXP LAN problem Forum
- Wordpad XP problem with doc files that worked ok using Win98 Forum
- Problem with remote registry win98 Forum
- Rave.mp3 Win98 driver problem Forum
- Problem? How to resolve win98 system file opening when I t.. Forum
- Latitude D600 Paralell port problem & Win98 install Forum
- Strange Win98 Problem Forum
- More resources
Actually, I have an extra hard drive laying around somewhere. How easy will it be to replace the old hard drive?
