Need URGENT help!
Forum Windows Vista : Vista General Discussion - Need URGENT help!
Hi guys, I recently built a computer, for the first time. Everything went fine until I went to install the operating system. I was installing vista, with a boot disc and halfway through it froze! Now im getting BOOTMGR is missing. I also tried to boot it from the disc, but it says DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. It just keep on looping this, I also tried to use my XP disc, nothing works. Does anyone have any advice? Thanks.
Sponsored Links
have you checked bios settings to make sure the boot sequence is correct? Also, perhaps something came physically unplugged on the inside of your computer?
------------------------------ MSI P6N SLI Platinum || Q6600 B3 @ 3.0Ghz || EVGA 8800 GTX (625/1550/2020) || 4 gigs Mushkin Enhanced DDR2 800 (5-5-5-18) || 2xWD Raptors (200 gigs) 1x Seagate Barracuda (300 gigs) || HT Omega Striker Sound Card || Coolmax 700W Modular Power Supply
Reply to rayzor
Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Need URGENT help!
There are 1141 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
