Microsoft Windows never lets us down when it comes to BSOD amusement and at the 2008 Summer Olympic Opening Ceremonies it strikes again With 70 million viewers watching, a record for non-U.S. Olympic Summer Games viewership, how many people do you think Read more
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
MIT researchers have started putting entire gas-turbine engines on tiny silicon chips. With the help of some military funding, researchers have fashioned millimeter-sized compressors, combustion chambers and turbines and placed them on layers of silicon wafers. Read more
Delft (Netherlands) - A PhD student at the Delft University of Technology in the Netherlands has constructed what he says is the world's most advanced walking biped robot. Read more
Welcome to part four of our Holiday Gift Guide coverage. This time around, the Tom's Hardware staff picks its favorite components for your wish list rounding out 2008. Read more
Recent price drops have made 4 GB DDR2 dual-channel kits affordable for even the most cost-conscious buyers. We pushed nine models to their limits to determine best value for a broad range of users. Read more
We tightened the budget on this month’s enthusiast-level system while loosening our belt for the low-cost gamer box by a similar percentage. Today we gauge the effect of these changes on performance and value and compare to last month's machines. Read more
On this, the second day of our System Builder Marathon, Don turns down the price tag of his mid-range build looking for a sweet spot just above the $1,000 marker. Let's see what sort of hardware he found for it! Read more
Tom's Hardware Forums »
Homebuilt Systems
General Homebuilt »
BSOD-Core2Extreme QX6800, please help
Page :
Previous
| Author |
Thread : BSOD-Core2Extreme QX6800, please help
Profile: stranger
More Information
Hi guys I have a problem where if my system gets stressed, it crashes and restarts. It's a new system I put together myself, and its driving me crazy, so I would appreciate any help.
Related Product
Profile: stranger
More Information
finally found out how to check the GPU's temperatures. They are at 78degres Celcius at idle... could this be the problem? |
Profile: addict
More Information
78 is much idle maybe it cant handle when load.. both cards at 78? how many fans u have at ur gtx's? i would say the normal is 60-65 idle with a gtx |
Profile: member
More Information
Profile: stranger
More Information
thanks for the advice guys.
Profile: member
More Information
Honostly.. I would be VERY surpriced if it didn't turn out to be one of your memory sticks.. |
Profile: journeyman
More Information
This is not an hardware error. The bad_pool_caller error on BSOD indicate an driver error. That stop sign is the stop code and he points you to a bad driver. Under the 0x0000050***it shood be a name of the driver if some concrete one, if not then its a blank line. so you need to reinstall that driver, if you can find out what that is. |
Profile: member
More Information
Profile: member
More Information
In any case.. if you have the Corsair XMS2 that runs at CL4 and not the CL5 your memory voltage is lower then it's very minimum (1.9 instead of 2.0 if you read the manual) What RAM do you have exacly?
Profile: stranger
More Information
thanks alot for the advice gys, its much appreciated!
Profile: journeyman
More Information
That is possible to, im not saying he shouldn't check his RAM but for bad RAM usually comes some of this BSOD: UNEXPECTED_KERNEL_MODE_TRAP-more common for overclockers, PFN_LIST_CORRUPT-this is in 99% bad RAM or PAGE_FAULT_IN_NONPAGED_AREA-this is also usually bad RAM and your statement "OR it could be his RAM and drivers fail because of it" would most probably be this message from BSOD. |
Profile: member
More Information
Profile: stranger
More Information
xela i think there might be something to what you're saying.
Profile: member
More Information
About your edit, I found this:
Profile: stranger
More Information
