Registry setting for one primary drive to other system primary drive for default
Last response: in Windows 2000/NT
- How do I set my default folders to the D drive (HDD) while keeping my C drive (SSD) the primary one? Forum
- How to disable WinXP installed on primary drive so it can be used as a secondary drive with all other data intact. Forum
- Solveddo one need to create a primary partition on second hard drive Forum
- SolvedSetting up hdd as primary drive with ssd as boot drive Forum
- SolvedSSD not booting as primary drive; System still recognizes old boot files Forum
- SolvedHow to set an HDD as the primary drive Forum
- i replaced a dead primary hard drive with another used one. Computer doesn't recognize it. whats wrong? Forum
- SolvedI have a Samsung 840 Evo as my primary drive, I tried to set up a second 840 Evo as a USB drive and it would not even show up Forum
- SolvedHow to set SSD as primary hard drive? Forum
- How to make a secondary drive my primary one (C)? Forum
- How to properly set Samsung 840 Pro as a primary drive? Forum
- Install old sata primary hard drive to new system Forum
- How do I wipe my primary boot drive and set up a new raid 0 configuration? Forum
- Removed damaged IDE drive now system won't recognize SATA primary Forum
- Set HDD as primary and SSD as secondary (but keep it as a boot drive) Forum
- SolvedUsing M.2 ssd currently used as hard drive cache as primary drive Forum
- Stuttering on other displays when I set primary monitors refresh rate above 60. Forum
- SolvedCan I use a dead laptop's HDD as my primary boot drive? Forum
- Solvedchange primary hard drive for downloads Forum
- SolvedSwapping mSATA drive to a different mSATA for primary drive (C:) Forum
- More resources
