Alaska is calling a routine maintenance check gone wrong "the worst-case scenario", after a technician accidentally wiped out a series of crucial government data. Two sets of back-up data were also corrupted, and Microsoft consultants were unable to retrieve the data. Read more
his morning saw the official opening of Apple’s latest flagship store in downtown Boston. Read more
Google has pie on its face after staffers accidentally deleted the company's main official blog Monday night and a user unaffiliated with Google temporarily took possession of the Web address. Read more
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
How far are PC graphics away from reality? Tom's Hardware takes a second look at the effects and tricks used currently by game developers to achieve more realism than ever before. Read more
Functionality, elegant design, and solid build quality characterize these mid-tower cases. They offer enough space for several hard drives and graphics cards, making them the ideal foundation for enthusiasts. Read more
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, though, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
In Part I of our power supply roundup, we went through five mainstream PSUs rated at up to 700 W. Round two sees us tackle another seven mid-range units in an effort to determine which power supply deserves your attention. Read more
| Bottom | |
| Author |
Thread : First-Timer mistake, Help!
Profile: stranger
More Information
I am putting a Non-overclock system as follow:
Related Product
Profile: Forum Fixture
More Information
Profile: newbie
More Information
Profile: stranger
More Information
Thank you for your help,
Profile: newbie
More Information
Check all your power connections (RAM seatings also). Make sure your extra video card power adapter is plugged in if it has one.
Profile: nimble knuckle
More Information
Unplug the power supply from the wall, wait a few minutes, and then plug it back in and try again. This is usually worth a shot in cases like this. |
Profile: stranger
More Information
Yes, I was able to install Window on the system before the incident. |
Profile: newbie
More Information
So what happened was this.....?
Profile: stranger
More Information
Yes, you are right. I switched the rear to front audio panel while playing a dvd. Again thank for your time and help |
Profile: newbie
More Information
Something that has to be asked....Do you have another Vid card possibly that you can install?
Profile: stranger
More Information
yes,
Profile: newbie
More Information
I'm afraid we are nearing it to the mobo brav3h3art. Something like the Southbridge for example could have been damaged. The only real way at this point, to be sure, is to get an absolute bare minimum set up together that should fire up. If a NB or SB chipset was damaged the mobo is toast.
Profile: stranger
More Information
Thank you VideoQuasar,
