Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Strange problem with XP Start Menu
Hi,
I encountered a strange problem with the start menu of Windows XP. It started after launching a series of 100 Windows updates so I wan't really say which one caused it. (and I'd rather not turn back my system)
The problem is that start menu entries in the root of the All Programs Folder get deleted every time I restart my computer. The ones in subfolders stay. This is also the case if I go take a look at the folders in "Documents and settings", so the shortcuts really disappeared there. They're not hidden since I set Windows Explorer to show hidden files and I don't see them. What I do get is the following chortcut:
http://users.telenet.be/benny.van.rossem/Public/strangeprob.JPG
It always comes back after a restart if I delete it. If I take a look at the properties, I see the following:
http://users.telenet.be/benny.van.rossem/Public/strangeprob2.JPG
Sorry 'bout the dutch language, but as you can see it's a shortcut to "My Computer". And it really works that way: if I click on it, "My Computer" opens in a new window.
Does anyone have any idea what I can do to resolve this?
I already executed the following command: "regsvr32 /i shell32.dll" and I also checked the User Shell Folders entries in the windows registry but they seem to be fine...
Thanks a lot,
Davy
Sponsored Links
Hi D@ffy
I am having EXACTLY the same problem! Did you find a cure?
Reply to blumf
There are 1150 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
