News
Microsoft ships first post-beta 2 build of Vista
Published on June 27, 2006
Late Friday, Microsoft shipped Windows Vista build 5456, its first post-Beta 2 version of the next major Windows release. Read more
Microsoft Releases New Build of Windows Vista
Published on September 25, 2006
Microsoft has released an interim build of Windows Vista to its usual testers as well as to some 100,000 of the participants in its Customer Preview Program. Read more
Microsoft Research Projects Go Google
Published on April 02, 2008
If you follow Google's public announcements closely, you will find that each of these messages carry a very subtle "do no evil" message and a certain tone that always makes you feel better about your own life. Read more
SD cards in tight supply due to Toshiba production problems
Published on December 27, 2004
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Latest Reviews & Articles
Tom's Holiday Buyer's Guide 2008, Part 4
Published on December 02, 2008
Welcome to part four of our Holiday Gift Guide coverage. This time around, the Tom's Hardware staff picks its favorite components for your wish list rounding out 2008. Read more
4GB Gets Cheap: 9 Dual-Channel Kits Compared
Published on December 01, 2008
Recent price drops have made 4 GB DDR2 dual-channel kits affordable for even the most cost-conscious buyers. We pushed nine models to their limits to determine best value for a broad range of users. Read more
System Builder Marathon: Performance & Value
Published on November 28, 2008
We tightened the budget on this month’s enthusiast-level system while loosening our belt for the low-cost gamer box by a similar percentage. Today we gauge the effect of these changes on performance and value and compare to last month's machines. Read more
System Builder Marathon: $1,250 Enthusiast PC
Published on November 27, 2008
On this, the second day of our System Builder Marathon, Don turns down the price tag of his mid-range build looking for a sweet spot just above the $1,000 marker. Let's see what sort of hardware he found for it! Read more
  Tom's Hardware Forums » Windows XP » Windows XP General Discussion » Please HELP! new build XP problems
Word :   Username :
Bottom
Author
 Thread : Please HELP! new build XP problems
Profile: newbie
More Information
I bought all my hardware from newegg.com, assembled, powered on, great! Lights, fans, everything works
put in XP install disc and started install, during setup I got an error for this file "usrvpa.dll", it prompted me to retry but I got nothing. Only other option is to skip, and it warns you that if you skip, XP may not run properly. Well I had to do something so I skipped, it finished and installed XP, but...everything seems to be going wrong...
pretty much everwhere i go from there, i have trouble. Tried to install SP1a from a disk and it said it had a corrupt file, tried it a few more times and it finally worked. Stuck my Abit mobo driver disk in...seemed to install everything fine, but sound isn't working, internet connection isn't working.
another strange thing is that i have a 250gb hard drive, but the OS only recognizes 132 gb...what's up with that?
I also tried installing the video driver for my ATI Radeon 2900PRO, again, hit or miss whether things actually install properly. Once i thought I had it installed properly, i tried installing a game. It'll start the install, everything will look good and then all of the sudden the PC boots. I go back into Windows, it allows me to continue the install...then i power up the game after its done and the game gets some error and shuts down within a few minutes.
What's going on? This is a disaster. Is it hardware or XP?
Related Product
Profile: addict
More Information
Ok after a REAL quick search I found that it may have something to do with a US Robotics modem.
Take out the modem or disable it and then try to reinstall windows. After you get windows working correctly try to introduce the modem
Profile: newbie
More Information
modem wasn't even connected during install though...and its not US Robotics
Profile: newbie
More Information
I ordered a new OEM copy of Windows XP w/ SP2c from newegg.com. The one I'm using now is a copy of Windows XP PRO (corporate edition) that an IT friend of mine uses for his installs. The only thing I could think of was maybe the hardware I'm using is having trouble with the XP disc.
If I get the same errors with this install, then I guess I'll eliminate the software theory. But I don't know where to go from there.
I think I said that
Profile: member
More Information
Sounds like the disk is old,not that the files ae not there, they just may be hard to read, try putting the windows disk in and see if it wants to repair the install, I doubt the hardware is having an issue with Windows software, If you remove the run32.dll it will force a new installation of Windows,but the real fix would be to slow the cd reader down to 16 or 20x, the disk you are using is a bootable I assume
Google Ads
