News
SD cards in tight supply due to Toshiba production problems
Published on December 27, 2004
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Microsoft fixes critical IE problems
Published on December 14, 2005
Microsoft this week fixed a widely reported flaw in its Internet Explorer browser that had been used by attackers over the past few weeks to take over the PCs of unsuspecting users. Read more
E-voting worries focus on failures, not fraud
Published on November 10, 2006
Major electronic voting machine problems occurred in at least six U.S. states during the country's midterm elections, underscoring that system failure, not fraud, is the biggest issue facing future races, voting-rights activists and technologists said this week. Read more
Microsoft patches 20 security holes in February update
Published on February 14, 2007
Microsoft's monthly security update for February has gone live. Though it marks the first update since the consumer release of Windows Vista, none of the 20 fixes are for the new operating system. Read more
Latest Reviews & Articles
4GB Gets Cheap: 9 Dual-Channel Kits Compared
Published on December 01, 2008
Recent price drops have made 4 GB DDR2 dual-channel kits affordable for even the most cost-conscious buyers. We pushed nine models to their limits to determine best value for a broad range of users. Read more
System Builder Marathon: Performance & Value
Published on November 28, 2008
We tightened the budget on this month’s enthusiast-level system while loosening our belt for the low-cost gamer box by a similar percentage. Today we gauge the effect of these changes on performance and value and compare to last month's machines. Read more
System Builder Marathon: $1,250 Enthusiast PC
Published on November 27, 2008
On this, the second day of our System Builder Marathon, Don turns down the price tag of his mid-range build looking for a sweet spot just above the $1,000 marker. Let's see what sort of hardware he found for it! Read more
System Builder Marathon: $625 Gaming PC
Published on November 26, 2008
This month's System Builder Marathon is all about your feedback to us. We've revamped our entry-level and mid-range PCs with new price points. Let's kick things off with what we think is the best value at a $625 price point! Read more
  Tom's Hardware Forums » Windows XP » Windows XP General Discussion » MSXML 4.0 SP2 Installation Problems
Word :   Username :
Bottom
Author
 Thread : MSXML 4.0 SP2 Installation Problems
GJX
Profile: journeyman
More Information
Hello,
I wasn't really sure in which section to post this thread so i just put it here.
My problem begins with me trying to install a HP Officejet 5510 All-In-One on my computer. During the installation i got an error.
I contacted HP support and they told me to install the MSXML 4.0 SP2
When i tried installing it i get an error "Could not open key: HKEY_LOCAL_MACHINE\Software\Classes\Msxml2.DOMDocument.4.0\CLSID. Verify that you have sufficient access to that key, or contact your support personnel."
I checked the regedit and found that there is no CLSID subfolder in any of the Msxml2 .4.0 folders.
I'm guessing that might be the problem.
How do i solve this?
Related Product
Profile: Forum Fixture
More Information
I have an old All-in-one HP officejet printer that is a bummer product to say the least. The way I get it installed is to plug the printer into the USB and when prompted from windows to install new hardware, I insert the HP driver CD and install ONLY the driver. If I install all that All-in-one HP junk it causes a lot of problems I'm sure HP support has no idea how to address much less fix.
GJX
Profile: journeyman
More Information
don't i lose alot of features by not installing the software that comes with it?
More Information
I use mine as a printer only. Are you using the latest drivers and software frm the HP website. That could solve some of the issues also.
GJX
Profile: journeyman
More Information
I think the problem lies in the fact that something is wrong with the Msxml2 registery corruption or whatever it is... meaning the installation doesn't fail due to driver version, but something else.
But i will try downloading the latest drivers and installing the 5510 manually, instead of the auto install given by HP.
I'd still like to get an answer about my registery problem
Google Ads
