Well I think this is the last "support ticket" Ill be opening (except maybe for one about a little question on the CPU) before Im 100% ready to build my new baby.
E6600 (will overclock it to 3 Ghz)
Gigabyte GA-965P-S3
Antec Earthwatts 500W
eVGA 8800GTS 320
OCZ 2GB PC2-5400 Dual Channel*
2 Hardrives (SATA and IDE)
2 Optical Drives (DVD/CD-RW, Both IDE)
TV Tuner (PCI)*
Maybe 2 Extra Case Fans (Cheap, so likely they'll be small, like 8mm/whatever?)
* Dont think they'll make any effect on this decision?
So basically, I cant order this on the US... shipping costs would be up the sky...
What Im going to do, is to buy the cheapest case I find, however I need to know about recommendations, specially in the field of SPACE.
Maybe someone with a similar configuration as mine, could give me an example of his/her case, so that I base myself on that when buying mine.
I dont care about fancy-ness, like glowing cases, or fluorescent light coming out of the back etc etc etc
Just the ugliest and cheapest thing I can find, that works perfect for my new system.
My main concern is space... I dont wanna buy something that doesnt allow one of the parts to fit in.
I think the 8800GTS isnt that big right? Like the big one is the GTX?
Since I know almost nothing about ventilation, thats why Im saying Im thinking of 2 extra case fans (maybe the case will come with 2 by default), put in the "right" spot.
So in this sense Im a bit in the blue and dont know if, with my configuration in mind, a "spacey" case is a lot better than something that allows components to fit it but leaves no space for almost nothing else.
Any suggestions? So I can see the pictures and all, and try to find a similar case over here?
Thanks for your time
Gigabyte GA-965P-S3
eVGA 8800GTS 320
TV Tuner (PCI)*
