my pc died and was fixed by a friend, there are two partitions on the hard drive, what were the C & D drives, the C drive is 29.9gig and has remained unaffected. however, what was the D partition (which is now the H) is in RAW format and windows will not let me format it. i'm not worried about losing anything that may still be on it, but it's 427gig and me little C drive's getting full up fast!
You can always download a copy of the GPARTED live cd (http://gparted-livecd.tuxfamily.org) and format the RAW partition in what ever format your beloved XP likes (NTFS, fat32 etc..)
Good luck
Steve
when i was trying to save the pc i reformatted the drive as fat32 because i didn't really know what i was doing, when he got it working again, the drive was RAW.
As I said you can reformat that RAW partition with GPARTED you may even be able to extend your working partition to the full drive capacity if you want. In case I was not clear, by using this program you will not (unless you want to) format over the working partition.
Message edited by acron1 on 01-24-2008 at 07:22:06 PM
hey acron I have a question
I Dont know of GPARTED but would like to know if it puts the partition in to a propiatary format. I know some of the other partitioning progs. cant be recognized by windows in future upgrade attempts.
I am going to upgrade and can see where this could be helpful
I know if you use a win98 or winmill to format the HD, XP says it's not compatable with that format and if you are going to install XP of a clean disk without a bootable CD, MSFT has a set of Boot disks you create to format and copy the install files to for the instalation
Message edited by gone fishin' on 01-27-2008 at 02:35:09 PM
In windows xp, Go the control panel - administrative tools - computer management - storage - disk management
Here you will see all drives on the system, it doesn't matter if they are formatted or not, if the bios sees it, even if you don't see it in my computer, they will be here and you can configure/format erase or whatever. You can do whatever needs to be done in this snap in.
Message edited by cranbers on 01-28-2008 at 10:58:23 AM
------------------------------A+ Certified 220-601 and 602
Antec Nine Hundred Gaming case/Core I7 920/Asus P6TSE/EVGA GTX 260/4GB OCZ 1600/Win 7 64bit
Reply to cranbers
