Tom's Hardware > Forum > Windows XP > Configuration & Customize > Converting new Vista machine to XP issue
Forum Windows XP : Configuration & Customize - Converting new Vista machine to XP issue
Hello all,
I'm converting a Vista machine (purchased new with Vista on it) to XP for a customer of ours because the USB-to-serial-adapter that they need doesn't work with Vista.
I bought an OEM (full) version of XP and put the CD into the machine. When the "Welcome to Microsoft Windows XP" screen pops up the "Install Windows XP" option is greyed out and doesn't allow me to begin the installation of the OS. If I click on the greyed out "Install Windows XP" option the PC just beeps.
I thought this would be fairly straight foward but I'm missing something.
Any thoughts?
Message edited by Rhino on 01-21-2008 at 05:35:04 PM
Sponsored Links
You will need to format the drive. XP is detecting a newer op system or vista doesnt want to be down graded. Either way its the same.
I cant remember the exact procedure but if you explore the disk(I dont have one handy) you will find the format command that you need to run. If in doubt there is a readme that will explain more on the disk.
Reply to pat mcgroin
Hi,,
You have to install virtual PC 2007 before installing XP on a Vista platform. this will give the user 2 choices when they startup their machines.
happy installing
of u have any doubts u can call me at +60162636806
Mahednran
Reply to Anonymous
Boot from the CD instead of autorunning it inside Vista.
------------------------------ Software failure stories and rants at
http://www.techdeuce.com/
Reply to techdeuce
There are 1073 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
