i reinstalled windows on my other pc (main pc) and then tried to acces the internet, didn't work.
i went to see network locations and there wasn't any connection(LAN CONNECTION or something) i reinstalled windows again(yea i did) and i still had the same problem, anyone know how i can get on the web again?
i also have problems making a homenetwork between this and the other pc
anyone have a solution ? thx
and i think (im almost sure) that this is a software problem because this morning it was working and now its screwed up, any of you might know some software or programms that will help me out of this?
maybe i have a solution, i downloaded a recommended sound driver realtek ac'97 or something, and im trying to install it on my pc, but my problem now is to fix the network so i can put the driver from this pc on the other one, since i dont have a cd/dvd burner on this pc
When you reinstalled windows, did you install the motherboard drivers off the cd that came with the motherboard? or is this a pre-built like a Dell, HP, etc....?
Look under device manager and see if you have any yellow question marks or exclamation marks.
omgawd, i now run the cd of asus and it says audio driver etc, so this is prolly it lol, but then i think the internet will still be screwed cuz i never had this before, but i will tell it here, thanks alot for the help
it worked both internet and audio man thanks alot
it was stupid from me but i thought i didn't have to because it said support cd so i thought it was a manual or a disclaimer or something
ok but one more question,
when i play music now it doesn't say 'cannot find sound card' but there just is no sound out of my speakers... very weird anyone know wha tthis is?
