Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Need help, can't hook up sound on my motherboard
Forum Homebuilt Systems : General Homebuilt - Need help, can't hook up sound on my motherboard
Motherboard :(
http://www.newegg.com/Product/Prod [...] 6813138027
I cannot get the drivers correct, I have to press reset to make the motherboard turn on the monitor (the motherboard powers up on 1 click)... Also, I have running vista premium and I don't have any sound, as a matter of fact Vista doesn't recognize my speakers at all....
About the jumpers how do I insert them? I face the top row facing up and the bottom row facing bottom...
Sponsored Links
I couldn't find any vista drivers for the mobo, so that may explain why vista won't recognize the sound chip.
http://www.biostar.com.tw/support/ [...] 6100%20AM2
http://www.biostar.com.tw/support/ [...] 2(Ver.3.x)
If you have xp, I suggest you install xp, all drivers, all apps, finally insert vista dvd/cd to upgrade. That's how I got my friend's laptop working perfect in vista.
Reply to akhilles
There are 1138 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
