Archived from groups: alt.games.quake2 (More info?)
Hi,
Margolis suggested that I put this in a new thread. Ok, here's the deal.
When I run the MP, it crashes. It might happen while loading, or after an
hour of play, or anywhere between. There's never an error message. The
colors get goofy for a second, and then it's gone. It's not minimized. It's
like I never started it.
"Tom Chaudoir" <news@clocktech.com> wrote in message
news:AQRkc.3084$ee7.2888@twister.rdc-kc.rr.com...
> Hi,
an
It's
> Any ideas?
> Best,
> Tom
Hi Tom,
Some shots in the dark:
I noticed the xatrixpatch on your ftp site. Did you install it? If so,
try uninstalling.
Also, did you install q2admin? I've had problems with single player
when its installed.
What OS are you running? Memory, etc.
And lastly, did you have this problem with an on-line game or just sp?
news:n8%kc.6136$ee7.801@twister.rdc-kc.rr.com...
> Hi George,
> Answers one by one.
> "George M. Reagan" <georgeunderscorereagan@hotmail.com> wrote in message >
> Hi Tom,
> so,
> > try uninstalling.
> I did install it, but had the problem before that. The problem is with the
> Rouge MP anyway.
The Reckoning is in the xatrix folder, BTW. If you put the wrong
gamex86.dll in the xatrix folder, bad things will happen.
news:sMWdnYQ0KLjkjgjdRVn-tA@comcast.com...
In other words, if you had installed the 3.2 patch and then xatrix later, it
probably put an old one in there. So in that case you need to take the 3.2
file from baseq2 and put it in the xatrix folder!
Doh! And furthermore Duh! For some reason I had Xatrix, Rogue, Reckoning,
and Ground Zero switched around in my feeble mind. Thanks to all who pointed
to my error, and sorry to Margolis, who I tried to "correct".
All the files are in the right places, and they always were. The reckoning
seems to run ok now, but only time will tell. Right now I'm hot on GZ SP.
I'll put up a reckoning server on Saturday if we can get at least one
veteran to take point. 4 rookies poking around at random can get tedious.
Running the server would be an acid test to see if the problem is really
resolved.
news:CDklc.14429$u_4.6950@twister.rdc-kc.rr.com...
pointed
> resolved.
> Best,
> Tom
Hi Tom,
I think my major mistake was to make my server PUBLIC. I should be
there to help with the effort.
